NEW BBC HP?
STINGER477
NEW BBC HP?
Post by STINGER477 »
My father-in-law put a new BBC with an OX-Drive 2.55-1 turning a 80" 4-blade "R" at the 3.5mark and he's turning 5300rpm WOT, any guess as how much HP. he's putting out?
GCRedfisher
Re: NEW BBC HP?
Post by GCRedfisher »
There are 14 different "BBC's" that have been produced over the years ( not counting the aftermarket)
Have no idea which one he has so to just guess.....I'll say 2000hp at least! :D
Seriously though, which engine does he have, how's it built? Without more info, it would be guess work.
Been There, Done That and Probably Broke It! If You Ain't Living On The Edge, Your Just Taking Up Space!
Whoever said "The Pen Is Mightier Than The Sword" never encountered automatic weapons!
Chaseh
Re: NEW BBC HP?
Post by Chaseh »
I'm gonna say around 600. Buddy has dynod 600hp bbc 496 with a 2.68 box and 4 blade 84" superwides turning the 2 mark or better
STINGER477
Re: NEW BBC HP?
Don't know the builder, but it was built to go in a "Tractor Pulling Truck" but they never ran it, and the guy needed some money and now its on an airboat, and we are trying to guess by the RPM and gear ratio and pitch what its making.
RJC5778
Re: NEW BBC HP?
Post by RJC5778 »
can you post the displacement on this motor? bore, stroke, cam specs, carb, all that jazz, must be a torque monster to spin a prop like that or the cage gap is small causing the prop to cavitate, I have a dyno tested 593hp airboat bbc 498 ci with a 2:1 belt drive spinning a 3 blade ngr 80" dia right at the 2 mark or a little under, motor holds 590+ torque from 3500 up
