What prop is best for 220gpu
Birddog247
Post by Birddog247 » Fri Feb 12, 2010 5:21 pm
currently have 6 blade warpdrive on a 12ft glass hull. Pushes ok but needs to be redone it is beat up! would not mined to try a diffrent prop instead of wasting time on this one. Just wondering which prop is best for the 220 on 12ft glass.
12ft Palm Beach
stock 350sbc
2.1 gear/80"NGR
"Save a tree; eat a beaver"!
josh_2562
Re: What prop is best for 220gpu
Post by josh_2562 » Fri Feb 12, 2010 5:38 pm
I had a 13'6 laser with a 220 and heavy rigging. I had a 68" 6 blade warp drive. I went to a 72" sensenich Q. My boat would run some dry. I put the Q on there and it was night and day. I had about the same top speed but the Q has way more push on the bottom end. I was told I should have went with a 70" so I could put more pitch in it to lower my cruise rpm.
harley
Post by harley » Fri Feb 12, 2010 5:42 pm
H Series Blade
High Performance Propeller System
For Use On Direct Drive Engines And Reduction Units
2008 Wood Court Plant City, FL 33563
Ph: 813-752-3711 Fax: 813-752-2818
http://www.sensenichprop.com
3 Blade
68” to 82”
Diameter
Carbon Fiber Construction
8 Inch Wide Blade
100 - 350+ Horsepower
3000 Maximum RPM
Direct Drive and Reductions
Left & Right Hand Rotation
66” - 86” Diameter
2 Blade
66” to 80”
Diameter
Recommended Combinations:
Lyc. O-290, O-320, O-360
2 Blade 66” - 72”
Cont. O-470 & GPU
3 Blade 68” - 74”
Cont. O-520, Lyc. O-540
3 Blade 68” - 78”
4 Blade 72” - 80”
Cadillac 472, 500
3 Blade 68” - 78”
4 Blade 72” - 80”
*These are recommendations only
Your application may differ
4 Blade
70” to 84”
Diameter
Sensenich’s “H” Blade carbon fiber ground
adjustable propeller was designed with the
sport airboater in mind. This snappy, high
speed propeller combines good dry running
with very fast top end speed. These blades
can be used on all direct drive automotive
and aircraft engines. It can also be used on
engines with reduction units for increased
throttle response.
Suitable for 1.5 up through 2.3 reductions
MEAN GREEN DOLPHIN MACHINE
14x8 Diamondback / SBC Power.
"ALL THROTTLE NO BOTTLE"
watersports7
Post by watersports7 » Sat Feb 20, 2010 9:08 am
:D
12' Predator / Lycoming 4 Cylinder / Old Skool 68x38 Stick Prop
Perfectly said by Lycoming: Some engines purr like kittens. These roar!
BenBad
Post by BenBad » Sat Feb 20, 2010 11:43 pm
How much flex can be expected on a Sensenich 72 inch Q blade?
Rick Powers
Omaha NE
http://www.yourtalkingnow.com/
crackercwboy
Post by crackercwboy » Sun Feb 21, 2010 6:15 pm
I had the 72 and the 70 inch whirl wind and loved them both on my 220. I had a 6 blade on it before that, when I swapped to the whirl wind it was like a brand new boat.
watersports7
Post by watersports7 » Mon Feb 22, 2010 9:46 am
harley wrote:H Series Blade
3 Blade
68” to 82”
Diameter
8 Inch Wide Blade
3000 Maximum RPM
66” - 86” Diameter
2 Blade
66” to 80”
Diameter
2 Blade 66” - 72”
Cont. O-470 & GPU
3 Blade 68” - 74”
3 Blade 68” - 78”
4 Blade 72” - 80”
Cadillac 472, 500
3 Blade 68” - 78”
4 Blade 72” - 80”
4 Blade
70” to 84”
Diameter
throttle response.
When did YOU own a 220 :?: :?: :?: :lol: :lol: :lol:
