want to try a prop
lgower
want to try a prop
Post by lgower » Wed Apr 21, 2010 4:39 pm
I have an 0540, looking at new props, had a ww sig, great but leading edge came off and comp said it was my fault, looking to try an h,q or warp drive, maybe someones got one sitting or a broken boat right now that I could try, looking for a 72inch
Lee and DeAnne
0540 , Jimmy white Square nose , ss rigging
fhp6
Re: want to try a prop
Post by fhp6 » Wed Apr 21, 2010 5:38 pm
How did they conclude it was your fault that the leading edge came off?
Mike
:old_glory: FHP6
Citrus County Airboat Alliance (Member)
"USMC"
:florida:
lgower
Post by lgower » Wed Apr 21, 2010 6:19 pm
said i must of had an impact, but it is a known fact that they had propbs with the edges slipping , oh well, greay prop, jus tnot happy with cust. service
Lee and DeAnne
broncobill
Post by broncobill » Thu Apr 22, 2010 6:29 am
I had a leading edge come off of a prop less than a year old. Took out rudder drag link through the deck and a six inch crack in the bottom. Company would not do anything as a matter of fact hung up on me. I only wanted help replacing the prop not repairs to my boat. After that i swore off wood props. You never know when they get a bad shipment of wood and that makes it your fault.
red_neck191218
Post by red_neck191218 » Thu Apr 22, 2010 4:36 pm
I've heard good things about the Q-series and you wouldn't have to get a new hub. The new H-series 3B would be nice to if you wanted to go with a 3 blade, that thing looks mean.
PM me if you want me to get you prices or call me @ 813-714-2123 ask for Jake
ThxJakeSimmonsJLPmotorsports
crowhater
Post by crowhater » Thu Apr 22, 2010 4:53 pm
it is threads like this that make me glad I only use Sensenich. Don will take care of you if you have a problem. If I was you I would call Don and tell him your situation and I am sure he would let you use test a prop as long as you give him a credit card number until you return it. 813-752-3711
cntry141iq
Post by cntry141iq » Fri Apr 23, 2010 5:00 pm
NOT ALL water walker hubs will accept sensenitch blades .... so be ready to buy a new hub as well if you are not lucky.
