Warp 8 blade turbo prop
rotator75
Post by rotator75 »
Hi can anyone tell me I had a 8 blade turbo prop on a built 454 and it pushed like crazy,building a new boat with a 496 would I be better to go to 10 or 12 blade over the 8 turbo.Thanks.
EFI Jay
Re: Warp 8 blade turbo prop
Post by EFI Jay »
What ratio is your reduction unit?
Jay Vetzel
Sr. Program Engineer
Engine Calibration/Controls Specialist
Indmar Marine
321-403-1622
rotator75
Post by rotator75 »
2to1 rotator.
Duece
Post by Duece »
How would that prop work on 350 w/a 2.68:1 pushing around 350 ponies?
Duece
"Welcome to the Dark Side..."
rotator75
Post by rotator75 »
Well im not sure I had it on my built 454 .I had front blades at 10 degrees and back at 12.I spun it 5500 with 2to1 Rotator on a 16ft freedom craft with poly.I will tell you it will spin up alot faster than the whirlwind stumppuller I had.
dudda bug
Post by dudda bug »
got a 8 blade turbo, got with warp drive and there data that was in airboat mag. fixin to try one more thing before I give up on it. will repost in a bit!!!!!!!!
