Going from glass to alum hull ?'s
josh_2562
Post by josh_2562 »
I have a nice set of rigging for a fiberglass hull. I like the way it's set up. I'm thinking of going to a alum hull because I run the gulf most of the time. Can I use my rigging in a alum hull. Not sure what brand I'm going to go with but it will be a new hull. What's a good size hull for a lycoming 160 with seating for 2? Thanks for the help
cntry141iq
Re: Going from glass to alum hull ?'s
Post by cntry141iq »
yes just tell the company making your hull nthat you need runners for what ever spacing your current rig is ... best to take the boat to them whole and let them make the measurements for ya. little boat and the gulf usally do not go together well but it can be done .. I would suggest alumitech myself
chargedupoutlaw
Post by chargedupoutlaw »
u can use it u may need to cut strapps off bottom depending on how it was bolted ,, sometimes have to weld angle to bottom of rig ,, ive done it alot of times ! as far as size we usally go 12 0r 12 -6 x 7 on 4 cyl ,, but where u ride u prob need to go bigger , and if u dont run dry alot prob wouldnt hurt to go bigger... still run water great..
JB AIRBOATS/// outlaw custom hulls and rigging/// josh bunnell
Southern Style
Post by Southern Style »
As cntry said.. People actually request stringer width to be specific to their builds all the time.. The manufacturer can space them out however you like... They will normally have to add a stringer or two to make them even all the way across, but is done all the time..
KRVSA Member
SJRAA Member
KCCO
bondsman
Post by bondsman »
in the process of it now. took my glass hull with riggin to chargedupoutlaw he measured my riggin and is building my hull so i can drop the riggin in.just a little modification was needed to my riggin not much.
josh_2562
Post by josh_2562 »
Thanks for the help guys. I think a 12x7 or7'6 is what I'm going to be looking for. I started off in the gulf with a 8x4 mini. Where I run it never gets over 4' deep. Now to pick a builder. Any one know the going price for a new alum hull with 1/4 poly. I like the way the jb hulls and hamant's look. Thanks for the help
