what battery
elviswho
what battery
Post by elviswho »
What type of battery do you use, Gel or regular car battery.
airboatfever
Re: what battery
Post by airboatfever »
Irun two regular car batteries, would like to go with gels but i can afford regular ones
The original AIRBOATFEVER 500 caddy, 14' Gilleo, Sensenich 72x44 woody,
Trav-azz
Re: what battery
Post by Trav-azz »
You can run a regular automotive battery, a cranking marine battery, or a gel cell. The gels hold up to the vibration probably the best. The marine have both post and high cranking amps. The regular automotive batteries work good. You can get them in many price ranges with high cranking amps and long warranties. Everyone has there option. I have ran a dual terminal 75 red top optima for 4 1/2 years. My battery sits on the bottom of my boat, it doesn't have a tray or box(it takes a beating from the hill).
Hope this helps.
Trav-azz
Re: what battery
Post by Trav-azz »
If you don't run a alternator you may want to run a deep cycle.
JAMES
Re: what battery
Post by JAMES »
walmart maxx marine 5 yrs been running them o problems
NotAGuide
Re: what battery
Post by NotAGuide »
Northstar AGM (absorbent glass matt) class 27. Not totally necessary if only using it for starting purposes.
Professional JB Welder
Old 18' American hull, 470CID S&S, Ch3 2:1, 3-blade Whirlwind Whisper Tip
Swamp_Pilot
Re: what battery
Post by Swamp_Pilot »
I would use a marine cranking battery from Interstate or Sears. Personally use 2 of 'em with a Perko switch in between. Deep cycle and gel cell batteries will not produce as many amps for the dollar. If you have a high compression aircraft engine with large cylinder bores, you might need the extra oomph to start after running just the lights for an hour or two.
elviswho
Re: what battery
Post by elviswho »
Thanks for the input, Marine high cranking amps it is.
Cracker
Re: what battery
Post by Cracker »
Odessy is guaranteed full replacement for the first 3 years no questions asked, they are supposed to last 8 years, i have never replaced one yet in 5 years, I run a 925 CCA dry cell with no Alt, and it last all weekend !
Light weight too !
Cracker
http://www.flickr.com/photos/crackers_pictures/sets/
Free Men don't ask permission to bear arms !
8cyl-sled
Re: what battery
Post by 8cyl-sled »
Go with the Odyssey. You won't regret it.
Billy
big3country8
Re: what battery
Post by big3country8 »
I run a Braille 21lb 1380 cranking amps for the first 5sec of cranking. Gator hunted the last 3 weeks and still strong. Had it for around 6 months and no problems yet. It's dry cell agm if I'm not mistaken.
Temporary High
12' clendenin aluminum step with poly, 418 waterthunder, 2.68 OX, 9 blade saber, ATF rigged, nitrous outlet,, buttrax custom seats.
