Laser 13'6 still porpoises... bad
deltaninesix
Post by deltaninesix »
I have a 13'6 Laser with SBC 305. I also have an electric trim tab and my boat will slam the fillings out of your teeth. It porpoises so bad! Its a single rear driver with double front passenger. It seems though, that when I have people in the front and its not just me it rides better and doesn't porpoise as much... but it still does. I moved the gas tank all the forward and that didnt even help all that much. Do you guys think I have something wrong with my hull or is it just a balancing issue? I want to add a grass rake so that would add some weight to the front. I also looked at the angle of the motor while it floats... it is down a little bit in the back already which is one fix Ive heard. How much of an angle for a 13'6 boat is okay?
BANANA BOAT
Re: Laser 13'6 still porpoises... bad
Post by BANANA BOAT »
That boat need's screw jack's put in.They push the stringer's down,under the engine.inexpensiveI know the boat.We tried changing engine angle,That did not help.
CJB0470
Post by CJB0470 »
My 13.6 Cottonmouth porpoised when I bought it. I jumped a levy and broke the trim tab and bounced all the way back to the trailer. In 2005 I bought a new hull and adjusted the angle on the motor until it stopped. See if you can adjust the engine angle, if not use the screw jack to push the bottom down. Take it out and make small adjustments and see how it responds.
Chris.
"Always do right. This will gratify some people, and astonish the rest"
-Mark Twain
Whitebear
Post by Whitebear »
You mentioned it has a trim tab but you didn't say if the trim tab will stop the porpoising or not?
Its always a balancing problem and its always fixable.
Put a straight edge on those stringers to start with and see what ya have.
BANANA BOAT
We tried adjusting engine angle.No help. Screw jacks.Trim tab helped when we had the boat.
AirRanger
Post by AirRanger »
The fuel tank seems very far forward. Could it be that you have plenty of power to lift that heavy fuel tank above plane then the weight of it just keeps pushing the nose back down?
mrfixit
Post by mrfixit »
The fuel tank location is fine to help with the porpas issue . lower the back of the engine mite help. put the boat on a trailer level the bottom of the boat find a machened surface that is flat on the engine check it for level and make it so to start with from there I would try lowering no more then 3/8 of an inch. I t would be a good idea fi problem exist to check the botom for high spot or hook.
cowtown
Post by cowtown »
sounds like the hull has a hook in it , multiple jacks may be required to hold the hulls shape , just a thaught.
http://usfth.tripod.com
And Proud Of It !!!
deltaninesix
Okay thanks guys. Like bananaboat said, trim tab helps a lot compared to no trim tab but it's still bad. As for the screw jacks...
They go lengthwise down the center along with the stringers correct? And how long do I need them to be? And one more question, how far from the transom should they start?
Thx again guys!
AirRanger
Post by AirRanger »
The jacks don't go lengthwise, they go across (adjacent to) the stringers. Some boats have two and some have three.
Striker543
Post by Striker543 »
My old hull was the same way. 12.5 ft hull with a 350 DD and it would buck you out of the boat it was so bad. Even with the gas tank all the way up, toolbox in the bow, and two people riding on the bow, it still bounced like hell. The bottom also was awful - it was "re-glassed" by someone who did not know what they were doing and it resulted in lots of "pits" and an overall uneven surface.
Bought a new hull - exact same engine, prop, and rigging (except the gas tank moved back) - and it rides like a dream. Depending on the age and condition of your hull, it may be an option. You can pick up used glass hulls in "like new" condition for pretty cheap if you wait for the right deal.
mrfixit
Post by mrfixit »
You mite want to pull the rigging off the hull flip the hull over and check it with a long straight edge. if bad it could be repared.
Oh by the way is there poly on this boat. have seen poly installed bad cause all kind of problems.
Nozzle Head
Post by Nozzle Head »
This should help in what you don't want to find.
You can check it with scuba gear too if you don't want to pull the rigging? A straight stick of emt works if you don't have a t square?
deltaninesix
Okay, I just had a look. And even on the trailer I can tell the hull is "wonkey." It looks about as bad as the pic above. How can this be fixed, adding poly? Or does the bottom need to be re-glassed? I like the set up of the boat now so if I can get this one fixed for less than buying a new hull I would prefer to do that.
Nozzle Head
Lift the rigging and reglass, you may want to check your stringers especially around the bilge weep holes too.
Striker543
Unless you're good with glass, I wouldn't recommend trying to do it yourself - it's not easy to get it perfectly straight. Even if you hire a professional, by the time you pay them, you could probably be halfway to buying a new hull. You may be better off saving up to get another hull, used or new, as long as the used hull has a good bottom.
Now, I know very little about polymer, but putting polymer on may hide your hull issues. Some of those experienced with polymer will have to chime in.
cowtown
Post by cowtown »
why not build it up with steelflex2000, or other brand , and install a new sheet of poly if you decide to run poly, just a thaught!
And Proud Of It !!!
deltaninesix
That's kind of what I have been thinking of getting done. Fill the wonky glass with some sort of filler to get it smooth and give the polymer a flat base to start with. The polymer would hide any small imperfections and give me a decent bottom to start with.
BANANA BOAT
That was a new slick bottom when you got the boat.Cowtown has it right,screw jack's so the stringer's do not move.(bottom hold shape). hook in bottom near stern.other than that,the boat run's like a top
tkendall82
Post by tkendall82 »
Fill the low spots with Duraglas, then put a fresh coat of steelflex on it whether you put poly on it or not. Jacks will hold the bottom true but the bottom has to be flat to start with.
dusty burch
Post by dusty burch »
:violent1: sounds like u just need a new hull if u put all the work in that old boat it will just come apart and u will be where u are right now also jacks wont help with a bottom that is that bad
BANANA BOAT
does not need new hull,I'll say it again jack's(inexpensive).If they do not work,then consider something different.
bowhunterfl
Post by bowhunterfl »
My little hull did the same thing I put jacks in and it fix it for a couple of rides and know the bottom is so war out even the jacks don't help.
And filling the low spots with slick bottom does not help the bottom still flex the same
14' combee 454 BBC 2to1 belt drive spinnen 3 wirlwind master blasters.
BANANA BOAT
We filled the whole bottom with steelflex.It level.Jack's will make the stringer's rigid.If jack's do not work, the next hull you get might need jack's.I have a mint condition laser that use's jack's to prevent porpoising.
dusty burch
BANANABOAT wrote:does not need new hull,I'll say it again jack's(inexpensive).If they do not work,then consider something different.
if the bottom looks that bad it is had it :cheers:
