Tracking a prop
midnight rider
Tracking a prop
Post by midnight rider » Sun Jan 29, 2012 3:48 pm
Does anyone else track their prop off the transom rather than using the pitch marks on their prop?
In order to set my q I had to set one at pitch mark one and one at two. Way too much harmonics with them set by the molded marks on the prop
cummins diesel power
Re: Tracking a prop
Post by cummins diesel power » Sun Jan 29, 2012 3:52 pm
them marks arent very accurate. i used the marks to get me in the ballpark, but track
off the transom to get em the same. i think i have one on about the 1 1/2 and ones about 1 5/8
or 1 3/4 the marks are off slightly
15x7 1974 airgator,500 cadillac dd,74" q series sensenich prop, 1/2" uhmw poly.
18x8 2001 panther, 502 chevy, 2 to 1 century,3 blade 78" stump puller, 1/2" poly
swamp runner
Re: Tracking a prop
Post by swamp runner » Sun Jan 29, 2012 4:39 pm
personally , i wouldn't do that . home depot has protractors for around $10 . put it at the very end of the blade and set each blade the same .
12' HAMANT ULTRALIGHT - 180 LYCOMING - 68" CYPRESS SERIES
Bob in Canada
Re: Tracking a prop
Post by Bob in Canada » Sun Jan 29, 2012 7:21 pm
I've got "R" blades now . The marks seemed kind of crude and the whole blade is compound angles and sweeps so I used a magnetic base dial indicator on a heavy steel plate clamped to the transom to get the blade angles to match .
14x8 Diamondback , 2.38-1 Stinger , 350 GM Marine , Sensenich 3 Blade "R" prop
JAMES
Re: Tracking a prop
Post by JAMES » Sun Jan 29, 2012 7:28 pm
swamp runner wrote:personally , i wouldn't do that . home depot has protractors for around $10 . put it at the very end of the blade and set each blade the same .
IF U USE THE SAME SPOT NO MATTER WHAT BLD U START WITH THEY WILL BE THE SAME CURVES/ECT DONT MATTER FIND A REF. POINT AND IT WILL BE THE SAME #'S JMO TRACKING IS FINE AND I DO IT AS WELL BUT TO BE SURE ... U WOULD BE BETTER OFF WITH A DIGITAL PROTRACTOR AND 10.00 I DONT NO ABOUT MINE IS LIKE 100.00 FROM SEARS
poobought
Re: Tracking a prop
Post by poobought » Sun Jan 29, 2012 7:29 pm
Tracking them works just fine. With all the newer props having no straight edges for the digital protracters I think it is the most accurate way. I have set a ton of props this way with no problems.
dantheairboatman
Re: Tracking a prop
Post by dantheairboatman » Sun Jan 29, 2012 7:38 pm
I done own a digatal protracter other than my phone i app. In the Sensenich instructions is says to track the blades and that is how they instruct me to do so. I have no problems this way . I do get fussy and make sure they kiss each time then check again after it tq.Hope this helps.
Sensenich propellers dealer.
Airboat consulting.
Dan@352 812 2239
swamp runner
Re: Tracking a prop
Post by swamp runner » Sun Jan 29, 2012 7:40 pm
IM WITH U ON THAT IF U USE THE SAME SPOT NO MATTER WHAT BLD U START WITH THEY WILL BE THE SAME CURVES/ECT DONT MATTER FIND A REF. POINT AND IT WILL BE THE SAME #'S JMO TRACKING IS FINE AND I DO IT AS WELL BUT TO BE SURE ... U WOULD BE BETTER OFF WITH A DIGITAL PROTRACTOR AND 10.00 I DONT NO ABOUT MINE IS LIKE 100.00 FROM SEARS
http://www.homedepot.com/Tools-Hardware ... ogId=10053 this is the one i have , i compared it to a digital one and i was within .2 of a deg. .
midnight rider
Re: Tracking a prop
Post by midnight rider » Sun Jan 29, 2012 7:44 pm
[attachment=0]prop pic 02.JPG[/attachment][attachment=1]prop pic 1.JPG[/attachment]
Hard to tell from the pics but the molded marks are in line with the sticker marks In order to have the least amount of harmonic vibration i had to set it how it is in these pics, I tracked the trailing edge off the transom. using a digital protractor will not always work. right now if you use the protractor it will tell you there are 3* difference in the blades. but if you track it off the transom they are the same.
prop pic 02.JPG (81.46 KiB) Viewed 1337 times
prop pic 1.JPG (130.53 KiB) Viewed 1337 times
Tony480
Re: Tracking a prop
Post by Tony480 » Sun Jan 29, 2012 7:49 pm
That's the way to do it!
JAMES
Re: Tracking a prop
Post by JAMES » Sun Jan 29, 2012 7:51 pm
I HAVENT HAD THAT HAPPEN TO ME YET BEING THAT FAR OFF LOOKS LIKE 1/2 MARK
aherr520
Re: Tracking a prop
Post by aherr520 » Sun Jan 29, 2012 7:55 pm
that's what I do and works fine
aaof member
midnight rider
Re: Tracking a prop
Post by midnight rider » Sun Jan 29, 2012 8:00 pm
its a full mark. I ran it one time with them both on one and it shook the bolts that hold the bowl of my carb loose. Thats a lot of vibration. It makes me wonder, cause that is alot of variance for coming out of a mold. Btw it is a 71" Q on a 160 H2AD. I have run the H also and it was on the money. TIGO541 had the same deal with his R's. Makes you wonder if its the blades or the hubs, I want to make clear I'm not downing or bashing Sensenich, I love the prop and its crazy how hard it pushes my boat, but its def something all newbies need to know to check. Cause that will ruin a crank especially a four cylinder in a hurry.
aherr520
Re: Tracking a prop
Post by aherr520 » Sun Jan 29, 2012 8:08 pm
I would not worry about the marks just track it and you'll be fine,I just put a 74'' Q on and there is no vibration. I tracked it and then checked it with a digital protractor
aaof member
fl cracker
Re: Tracking a prop
Post by fl cracker » Sun Jan 29, 2012 8:17 pm
So how do you track a blade? Do use a zip tie off the transom or cage wire? Do you measure to the leading edge only? At night when I have my cage light on it looks like the blades are wobley as sh!!!!t front to back!
" I have two guns...
One for each of you "
2017 Al David / stroked LS
swamp runner
Re: Tracking a prop
Post by swamp runner » Sun Jan 29, 2012 8:28 pm
i have a 68 cypress , i set the pitch with the protractor i posted a yr 1/2 ago and never had a problem . i just now went and tracked it a few min. ago and it checked out perfect :mrgreen: areyou sure that your prop dowels aren't too long , not letting the prop hub bolt down flush against the crank ?
swamp runner
Re: Tracking a prop
Post by swamp runner » Sun Jan 29, 2012 8:33 pm
on mine , i clamped a metal ruler to the transum just barely touching the trailing edge of one blade then spun it around to where the other blade came to the ruler , it was perfect !!!
midnight rider
Re: Tracking a prop
Post by midnight rider » Sun Jan 29, 2012 8:34 pm
yeah they arent too long. how do you like that power shift, have you compared it too anything else. Thats the one that I really want to try next.
swamp runner
Re: Tracking a prop
Post by swamp runner » Sun Jan 29, 2012 8:44 pm
i love it , had a H it ran out of oomff , a 5 bld warp too noisey . dont have the $ to try others , maybe on the next boat .
Southern Style
Re: Tracking a prop
Post by Southern Style » Mon Jan 30, 2012 8:52 am
I have never done this.... Might wanna do this on my next day off... Wonder how far they might be out... The motor has no wobble, so it must be close, but confirming it will be comforting..
KRVSA Member
SJRAA Member
KCCO
BlowInIt
Re: Tracking a prop
Post by BlowInIt » Mon Jan 30, 2012 9:15 am
Tracking is the best way to go! I can re-set the pitch at any time in about 5 minutes on my 3 blade R series. My boat always runs smoooooth.
