R/C Airboat Prop
baggedsuperduty
R/C Airboat Prop
Post by baggedsuperduty »
Not sure which section to put this in but im looking for a four blade prop for my 52cc airboat engine. Got the aluminum hull built but now need the prop so i can do the cage and all. The recommended prop size is 20"x10" and i need a pusher prop. I was thinking about going with a 4 blade and drop the size a little bit. Let me know if you know anything. Thanks in advance
15x8 dyna-marine vapor boat with turbo'd ls2
14x8 jw with a cammed 500 caddy swingin a 72" whirl wind wisper tip built by me, my dad, and a good buddy
Big Block Glock
Re: R/C Airboat Prop
Post by Big Block Glock »
http://www.aircraftinternational.com/Pr ... Props.aspx
Here's the place for Carbon Fiber Pusher Propellers in the sizes your looking for. I use 20" and 22" myself. :cheers: :proud: :florida: :rebel: :rebel: :rebel: :rebel:
14x8 JB 350, 2:12 Rotator, 2-Blade 80" Water Walker Maximus
Post by :) »
The recommended prop size is for a 2 blade configuration more than likely. If u got to say 3 blade u subtract a inch in lenth and add a pitch number. I've never had any luck with the 3 blades on mine. Seems to bog it down, mine love the 2 bladfe props. Of course I'm running a 32 on mine too.
big3country8
Post by big3country8 »
I always ran master airscrew 3 blade pushers on mine and they make them up to a 20 I think.
Temporary High
12' clendenin aluminum step with poly, 418 waterthunder, 2.68 OX, 9 blade saber, ATF rigged, nitrous outlet,, buttrax custom seats.
baggedsuperduty
Well id like to run like a 4 blade so that i can go down to say an 18" x whatever i guess a 8. Reason for that is the motor is going to stick so far up in the boat and it doesnt really look proportional.
baggedsuperduty
:) wrote:The recommended prop size is for a 2 blade configuration more than likely. If u got to say 3 blade u subtract a inch in lenth and add a pitch number. I've never had any luck with the 3 blades on mine. Seems to bog it down, mine love the 2 bladfe props. Of course I'm running a 32 on mine too.
Ok so the recommended prop sizes are for a 2 blade and it says 20x8, 20x10 or larger. So if i wanted a three or four blade and was going to go with the middle prop which is 20x10 what size of a 3 and a 4 should i get?
baggedsuperduty
big3country8
I always ran smaller nitro motors. I had a .91 os with a tuned pipe and I'd run a 16-7 3 blade to lug it a Lil or 14-7 3 blade to twist it up. Not sure on the bigger motors.
Temporary High
Big Casino
Post by Big Casino »
WOW!!! these things have sure come a long way from the ol' "Cox 0.49" days ......
"...This above all: to thine own self be true..."
aherr520
Post by aherr520 »
I built an aluminum hull for my .60 size about 12 years ago and still never finished it, I think I need to get on the ball and do it
aaof member
Crazy Frog
Post by Crazy Frog »
A 4 blade pusher in that size is a rare bird...I have stacked 2 two blade props with some success...keep the same diameter and knock the pitch in half on each!
Post by :) »
If it says 20x10 and u want 4 blade u would go like 18x12-13. Something like that. I use masterairscrew props too.
Post by :) »
They r not that expensive, I'd get 3-4 and try them all..
baggedsuperduty
:) wrote:They r not that expensive, I'd get 3-4 and try them all..
Well i ordered a 20x10 3 blade from the website that someone posted above so i guess ill see how that goes. Where do you get yours from?
Crazy Frog
What ever u do...don't use a woodie around the kids...they can't take the water abuse! I know when we run MABA races..the Woodies are not allowed!!...I have seen the 3 blade composite blades come a part too! :salute:
gary
Post by gary »
Can you guys post up pics of your rc airboats? :cheers:
Crazy Frog
I have some in my S/A gallery under CrazyFroghttp://www.southernairboat.com/photopos ... hp/cat/722
ptr34
Post by ptr34 »
I run a 16x10 3blade master aircrew on my 50cc twin. Did what u said and it wouldnt turn i good
tons videos on YouTube ptr34
ptr34
Post by ptr34 »
Got a 5 blade prop I built that I will sell u.15x7
Big Block Glock
Here are my Carbon Fiber Propellers. The 2-Blade is a 22x10, the 3-Blade is a 20x10
baggedsuperduty
ptr34 wrote:Got a 5 blade prop I built that I will sell u.15x7
How much do you want to sell it for???
baggedsuperduty
Ok im having a major brain fart!!! I ordered a pusher prop but it dont seem like it will be spinning the right direction. So with the motor facing towards the back of the boat like a normal airboat do i need a pusher or a tractor?
ptr34
Post by ptr34 »
U need a pusher. 30 for 5 blade
baggedsuperduty
ptr34 wrote:U need a pusher. 30 for 5 blade
man for some reason it just dont look right. i guess ill have to study it some more, maybe i just got too much on my mind. I havent started the engine yet but im assuming when looking at it from the back of the boat its going to spinning counter clockwise and it seems that the prop is going to be blowing the wind the wrong direction. I bet they sent me the wrong one even though i ordered the right one.
So about your prop..... have you used it yet? Ill but it if its legit....you take paypal and can you ship it?
baggedsuperduty
just dont think it will be the right size for my motor because mine calls for a 20x10 or larger for a 2 blade. what you think? i see you work for a company that knows there s**t!!!
