New Boat Build
GTSIO-520
New Boat Build
Post by GTSIO-520 »
Ok, thanks to everyone who offered help on my previous post, "IGSO-540 or LS3" http://www.southernairboat.com/phpBB3/v ... 85&t=45091 . I have decided on the LS3, or at least a car motor at this point and I have started building the hull. I will start posting pictures as we go. The hull will be 14'x 7'9" or 8'. It has a 60" wide flat bottom. The rigging will be aluminum.
14'x8' Fast Eddie Alum. Hull, Alum. Rigging, 418ci Chevy LS3, 2.68 Rotator, 80" 4 Blade R.
12'x7'6" Hamant, Stainless Rigging, GTSIO-520, 72" Power Shift.
GTSIO-520
Re: New Boat Build
Post by GTSIO-520 »
.125" aluminum for the hull.
SwampNinja
New Boat Build
Post by SwampNinja »
Good luck. I will be tuned into this one.
I am here: http://tapatalk.com/map.php?pqvub0
"It is what it is."
GTSIO-520
Re: New Boat Build
Post by GTSIO-520 »
A few pictures of the hull build.
Half of the bottom
Half of the bottom
2012-05-16 17_opt9.jpg (56.52 KiB) Viewed 10956 times
T-Bars ready for install
2012-05-16 17_opt7.jpg (69.32 KiB) Viewed 10956 times
GTSIO-520
Re: New Boat Build
Post by GTSIO-520 »
Hull bottom with T-Bars installed.
2012-05-17 18_opt6.jpg (77.75 KiB) Viewed 10906 times
2012-05-17 18_opt5.jpg (64.51 KiB) Viewed 10906 times
GTSIO-520
Re: New Boat Build
Post by GTSIO-520 »
Starting to look like a boat!
a2012-05-19 16_opt.jpg (81.85 KiB) Viewed 10832 times
2012-05-19 16_opt.jpg (69.96 KiB) Viewed 10832 times
Southern Style
Re: New Boat Build
Post by Southern Style »
DAMN.......... Talk about starting from SCRATCH... Get on it man !!!! Looks great, will be following the post as well.. Love these posts.. Reminds me of when I was building mine and posting up.. Thanks for letting us be a part of your build !!!!
KRVSA Member
SJRAA Member
KCCO
GTSIO-520
Re: New Boat Build
Post by GTSIO-520 »
Has anyone ever powder coated their hull? I am thinking about doing it with this hull? Any opinions? I know it is more durable than paint but I am curious if it will hold up on the hull.
SDeatherage
Re: New Boat Build
Post by SDeatherage »
A buddy of mine owns a powder coating business. And I know he did a hull for a guy who races. And it had no polymer and they were running it on the powder on the bottom and it was holding up pretty darn good from what they said. They put extra coats on the bottom. It will wear out eventually but they were impressed. And I have seen other hulls fully powder coated and they were holding up well.
2016 14' X 8' Dyna Marine Revo powered by a TKE LS3 swinging a Sensenich 3 blade 81" R with a Ballistic 2.70 box. Fusion deck with 8.8 JL Audio speakers. Custom sea-dek on a Dakota trailer.
CONTINENTAL CRACKER
Re: New Boat Build
Post by CONTINENTAL CRACKER »
I talked with a guy that has a powder coat shop and also does airboat work. He said he recomends to do a flat color because it doesn't show scratches as much as a gloss color will,and from what I have seen it holds up good.
I WOULD RATHER PADDLE A CANOE THAN OWN A WATERPUMPER
GTSIO-520
Re: New Boat Build
Post by GTSIO-520 »
CONTINENTAL CRACKER wrote:I talked with a guy that has a powder coat shop and also does airboat work. He said he recomends to do a flat color because it doesn't show scratches as much as a gloss color will,and from what I have seen it holds up good.
That's a good idea, going with a flat color. I was worried about scratches and fading too.
GTSIO-520
Re: New Boat Build
Post by GTSIO-520 »
Some updated pictures of the hull.
2012-05-24 18_oppt.jpg (66.08 KiB) Viewed 10613 times
2012-05-24 18_opto.jpg (84.9 KiB) Viewed 10613 times
2012-05-21 10_opth.jpg (120.58 KiB) Viewed 10613 times
GTSIO-520
Re: New Boat Build
Post by GTSIO-520 »
Ok so it's time to order the prop and gear box, I am going to need them for mock up. I have decided to go with the 2.68 Rotator as I can not get my hands on a Stinger. Most have recommended either a 3 or 4 blade "R" for my set up but I am wondering why not the "S"?
Stephen09
Re: New Boat Build
Post by Stephen09 »
Nice build looks good will be posted
skinny99
Re: New Boat Build
Post by skinny99 »
GTSIO-520 wrote:Ok so it's time to order the prop and gear box, I am going to need them for mock up. I have decided to go with the 2.68 Rotator as I can not get my hands on a Stinger. Most have recommended either a 3 or 4 blade "R" for my set up but I am wondering why not the "S"?
The "R" just works good all around. Snappy and fun to drive with plenty of push on the dry.
3 Blades should be enough unless your building a particularly nasty LS3. The "R" series likes pitch.
Boat looks good! Thats a lot of work.
GTSIO-520
Re: New Boat Build
Post by GTSIO-520 »
I am either going with the WT 550hp or WT 418. I think the 418 is around 625hp? The new hull is around 7'9" at the gunnels so I need to keep the prop under 80" so I was thinking maybe a 78" 4 blade "R" or a 78" 3 blade "S" but everyone seems to like the "R" better?
BlowInIt
Re: New Boat Build
Post by BlowInIt »
You can pitch out a 3 blade R even with the 418ci. His race boats still only use three R blades for what its worth. Do not go with S blades.
BTW 7'9"= 93"s, you could go up to a 84" if you wanted.
deuces wild
Re: New Boat Build
Post by deuces wild »
if you want a shorter prop go with a 72 inch 10 blade warp drive hub and razer blades if you get the 550 then i would use 8 blade
SPEED THRILLS
Tony480
Re: New Boat Build
Post by Tony480 »
deuces wild wrote:if you want a shorter prop go with a 72 inch 10 blade warp drive hub and razer blades if you get the 550 then i would use 8 blade
I don't see any 72" prop holding 550 horses back with a 2.68 box.Hell I don't care if you put 12 razors back there.It should swing an 80" 8 blade razor like it was nothing!
DAGWOOD0520
Re: New Boat Build
Post by DAGWOOD0520 »
on the 418 you could run a 3 or 4 blade R, the 3 blade will be a little more like a hunt/play prop that snaps up quick and runs fast on the big end, the 4 blade will give you a little more on the ground and should cruise at a little lower RPM but will not be as snappy or as fast. Really comes down to how you want the boat feel when you hit the gas.
on the WT 550 with a 2.68 a 3 blade R is a really good match.
GTSIO-520
Re: New Boat Build
Post by GTSIO-520 »
I think I have made my decision, 80" 4 blade "R", 2.68 Rotator Box, WT 418CI.
Ruagatr
Re: New Boat Build
Post by Ruagatr »
Damn good choices!
Maddog
BigJakesrq
Re: New Boat Build
Post by BigJakesrq »
GTSIO-520 wrote:I think I have made my decision, 80" 4 blade "R", 2.68 Rotator Box, WT 418CI.
That is a solid base. I have the same setup more or less I run 82'' 4 blade R. You should be fine with the 80'' though.
GTSIO-520
Re: New Boat Build
Post by GTSIO-520 »
What RPM are you turning with your 4 blade? I am still on the fence as far as 3 or 4 blade? I need to make my mind up soon though!
GTSIO-520
Re: New Boat Build
Post by GTSIO-520 »
So I took a few measurements last night and I should be good with an 82" prop. I really want to go with the 3 blade R. Do you think a 82" 3 blade R will be enough prop for a WT 418? Seams most of the CM race boats run 3 blades.
BTW transom is in I will post some more pics.
