scorpion fulldeck question
norman simmons
Post by norman simmons »
i have a 12 foot scorpion with a 0360 on it , it has a 6 inch transom , its 7'5 wide and i was wounderning if i could put a straight valve 540 and get it to float that weight ?
yobee
Re: scorpion fulldeck question
Post by yobee »
Just add weight to make up the difference
glades1531
Post by glades1531 »
theres been on for sale on here for awhile with an upstack 540..... i new a guy who had a 550 cont . on one so i would say yes!
:rebel:
norman simmons
what is the weight diff in a 360 widedeck vs a straight valve small journal 540 ?
i have only about two or three inches of free board when im sitting
sidetracked
Post by sidetracked »
I have an o470 on mine. It sits low but it is fine.
MUGSHOT
Post by MUGSHOT »
I have a 6-1/2 transom 7'8 wide Hancock with a 220 gpu and floats just above the deck with no poly. Take a picture of the transom, I would like to see it.
2014 Derek Eaker sled with a IO540 5 Blade Saber....
Built By D@E Metal works in Homestead Fl. (786) 412-9018
12x7 7075T6 .125 Bottom Full Deck....
Maintained by Airboat Gus (786)236-8216
Proud member of the Airboat Association Of Florida (AAOF)
