LED LIGHTS?
hunter12
LED LIGHTS?
Post by hunter12 » Tue Aug 21, 2012 2:52 pm
Any advice on types, brands, kinds of LED lights or other lights that work great to mount to the cage for boating at night? or to mount at the bow of the boat that can double forshining down in the water in front of the boat... Advice on best places to mount lights, hooking them up on a switch? Any advice on a great spotlight to buy for driving at night? Thank you!
radtech
Re: LED LIGHTS?
Post by radtech » Tue Aug 21, 2012 3:10 pm
Mine are fog lights from Advance. Not very expensive and very bright. I wired 4 lights to the cage and ran to a switch on the console. It'll light up the night
PeaRiverOpossum
Re: LED LIGHTS?
Post by PeaRiverOpossum » Tue Aug 21, 2012 3:23 pm
I have these on my rake and love em. They pivot so you can point them down in the water. http://www.surpluscenter.com/item.asp?i ... e=electric
I got my cage lights from Nothern Tool. They are HID Xenon and they are AWESOME! http://www.ebay.com/itm/8-6000K-BUILT-I ... 932wt_1397
HASBEEN
Re: LED LIGHTS?
Post by HASBEEN » Tue Aug 21, 2012 3:50 pm
You might send KC5AKB (Ric) a p.m. or an e-mail.
He`s been experimenting with, testing, and fishing with several styles and brands of l.e.d. lights for
a while, and he`s in your area. He`s posted several threads and video`s of his tests on high end and low end lights. Good info.
Good Luck !
Hasbeen
15x7 Cyclone, 454 BBC Junkyard Motor / 2-1 Belt Drive/ 2 Blade 79" WhirlWind RQ/ Water Walker Hub
BRAB46
No Abla anything but AMERICAN
"When the Sun comes up, you better be running"
mwood7800
Re: LED LIGHTS?
Post by mwood7800 » Tue Aug 21, 2012 4:36 pm
if you want a great light try these
https://www.teslaleds.com/default.aspx
there 170 for a pair, put them up front, cage lights don't work, just blind the driver and passengers
hunter12
Re: LED LIGHTS?
Post by hunter12 » Wed Aug 22, 2012 7:59 am
I appreciate the info. I didnt think of that! Makes common since!
KC5AKB
Re: LED LIGHTS?
Post by KC5AKB » Thu Aug 23, 2012 10:28 am
Come on Bowfishing guys and gals Jump in with the info for
AC And Dc Lights the different types
I am still out on the LEDs for seeing fish
I do like leds for driving and the low draw on your aux
Bat when parked or camping and have your lights on.
BRAB45 RRAB 17
kriscad
Re: LED LIGHTS?
Post by kriscad » Mon Aug 27, 2012 11:11 pm
I have these on my bow fishing rig:
http://seeliteleds.com/products/true-wa ... shing-line
50W warm LEDS... Kill fish with them all the time!
From TN!! Not many of us up here!
CleoGerten
Re: LED LIGHTS?
Post by CleoGerten » Tue Nov 13, 2012 1:38 am
_______________________
Flexible LED Strip Lights
spotlight LED light
led strip light
air-roberts
Re: LED LIGHTS?
Post by air-roberts » Tue Nov 13, 2012 3:03 am
i can't get the running light i used to get without buying a hole roll witch is about $350.00 but loved them they are the perfect running lights
http://www.superbrightleds.com/moreinfo ... module/28/ these work good for the front running in red and green but check out all there stuff they even have reg bulb connector thats a led light aqnd vbery cheap
Air-RobertsImage
New & Used PROPs
WhirlWind prop dealer
boobidges
Re: LED LIGHTS?
Post by boobidges » Tue Nov 13, 2012 6:50 am
Check out blue water leds.they have a website.completely submersible,they stick on with 3m adhesive that really sticks,and available in several colors and lengths.every light on my boat is blue water.including a 16' rope around my cage and 2 on my transom that illuminate the water.
Sniper
Re: LED LIGHTS?
Post by Sniper » Tue Nov 13, 2012 9:56 am
You need to call Alex Vasquez he has intensity lighting and all he builds is lights for marine use he built all the lights on my Search & Rescue boat and they are awesome he has been building lights for years and has built all the lights on all my boats, if you want driving lights put them in front of you don't put them on the cage over head for driving if you do when you turn them on you won't be able to see very well the ones on my cage point off at a 45 to light up on either side of the boat and my driving lights are on my grass rake the big LED on my cage is to light up the area around the boat once I get where I’m going on the rescue or if I have divers or rescue swimmers in the water I also have LED around the inside of the boat for lighting the deck and interrior of the boat
magazine pics_8506.jpg (93.39 KiB) Viewed 2563 times
magazine pics_8471.jpg (182.06 KiB) Viewed 2563 times
Boat details_8030.jpg (61.18 KiB) Viewed 2563 times
HITMAN
Re: LED LIGHTS?
Post by HITMAN » Tue Nov 13, 2012 2:24 pm
I did a little testing of my own, not for running lights but for bowfishing, LED lights are great for lighting up the surface area but for penetrating the water and shinning down into depth for bowfishing and fish gigging I found the the natural brown/yellow of the High Pressure Sodium penetrates water the best and does not refract as bad as a white light. If you are looking for strictly a running light or to light up your interior then the LED is the way to go. Just a FYI, I do have to run a generator to use the HPS lighting system on my bowfishing rig.
"THE ONLY THING WE HAVE TO FEAR IS FEAR ITSELF"
http://www.h2outfitting.com
11.5' aluminum open hull powered by an 0540 with a 6 blade warp drive.
sseater
Re: LED LIGHTS?
Post by sseater » Tue Nov 13, 2012 3:04 pm
lbdb1a
Re: LED LIGHTS?
Post by lbdb1a » Tue Nov 13, 2012 10:37 pm
I use these for Fog Lights...mounted low....not to bright...can run in the fog..
Larry
PICT0690 (670x503).jpg (234.58 KiB) Viewed 2378 times
lbdb1a
Re: LED LIGHTS?
Post by lbdb1a » Tue Nov 13, 2012 10:44 pm
Mounted on the weed guard as low as practical...
Larry
PICT0688 (640x480).jpg (194.25 KiB) Viewed 2375 times
