Ground Wire Burning Up
khvann40
Post by khvann40 » Mon Oct 29, 2012 11:03 pm
Looking for a little help from the automotive pros on here. So... Sunk the boat this weekend for the first time almost too proud to admit it hence the delay in post seeing as I sunk it on Friday evening and just now posting... but have run into an issue now and need help. Motor was only under water for about 5 mins. Drove into a cove and went to turn around and made the deadly mistake of turning left into the wake w a 13'6 boat and backwash caught up with me tried to gas out but was too late. Over she went in about 3 foot of water. Had 3 big guys on the boat in excess of 700 lbs so didn't help the situation until I needed them to help me turn the boat over and push to shore. Now that you know the story here is what I have done so far. Drained all fluids and refilled with cheap oil mixed w SeaFoam as well as in the fuel as well. Pulled all the plugs and turned over engine manually to try and flush moisture out as much as possible. Took the carb off drained and cleaned it up not much moisture in the intake manifold when I took carb off. Replaced ignition coil, distributor cap, rotor and module bc that probably needed to be done before I even sunk the boat. Went to crank this afternoon and ground wire shredded. Read many posts from all over and overwhelming consensus was the starter was bad. So changed starter and still same problem. It hasn't burnt up again but I haven't kept the starter going for that long bc every time I hit the starter I can see the electrons go through the ground wire and the wire from the battery to the starter and hear the wires start to crackle. I'm at a loss for words as to what to do next. I was planning on changing all of my battery wires and connections next in case of corrosion. Its definitely shorting out somewhere and sending everything to that ground wire but just not sure where. The engine isnt seized up bc I can turn the motor by hand by the prop but when I hit the starter it turns very very slowly and only a little at a time. If anyone else has experienced this or has any info on what to try next please feel free. Thanks ahead of time for the help.
Keegan
Whitebear
Re: Ground Wire Burning Up
Post by Whitebear » Mon Oct 29, 2012 11:40 pm
Disconnect all the wires except the starter, then use a wrench or screwdriver to kick the solenoid and see if your still getting the same thing. I might be some wires got cut or crushed in the roll over you described. Its obvious that with the new starter it isn't the starter, assuming its the right starter.
khvann40
Post by khvann40 » Mon Oct 29, 2012 11:46 pm
Definitely not the starter its a good starter off another 350 that I have. Just tried a new battery and does the same thing. Wondering now if it's my battery selector that has shorted out. About to take connectors off of that and run directly.
Whitebear
Post by Whitebear » Mon Oct 29, 2012 11:50 pm
Yeh get ya a strait run from battery to starter and try it.
khvann40
Post by khvann40 » Tue Oct 30, 2012 12:08 am
Alright not the battery selector either... Beginning to think I just need to redo all my connectors on all the cables
khvann40
Post by khvann40 » Tue Oct 30, 2012 12:17 am
In my dash I have a fuse block for all my gauges, ignitions, lights, etc... I haven't tried changing all the fuses yet and can see some of them have moisture in them particularly the ignition fuse. Guess I'll try changing these next. None of my lights, are working either which I did not expect them to but bilge pump worked when we pulled boat out to get water out but now won't work...
Comanche-pup
Post by Comanche-pup » Tue Oct 30, 2012 12:18 am
khvann40 wrote:Alright not the battery selector either... Beginning to think I just need to redo all my connectors on all the cables
it's not shorting it opposite, you have a bad connection, probably where your cable is bonded to the connector on the battery, where ever the cable is getting the hottest is where you bad connection is at
khvann40
Post by khvann40 » Tue Oct 30, 2012 1:13 am
Good tip. Thx for the help. Will try in the morning.
K-mac
Post by K-mac » Tue Oct 30, 2012 7:57 am
Take a set of jumper cables, and hook from the neg. battery post, to the starter
housing,or engine block then hook the other jumper from the jumper clamp on the first cable at each
end. try to start your engine, if it seems to do OK, change your ground cable.
PS. use a heaveir cable if this is the case, I've seen many boats with way too
small battery cables on them. :rebel:
If the south would'a won we'da had it made!
air-roberts
Post by air-roberts » Tue Oct 30, 2012 8:06 am
definitely bad continuity somewhere check all connections and disconnect one at a time to isolate problem
Air-RobertsImage
New & Used PROPs
WhirlWind prop dealer
gso480jr
Post by gso480jr » Tue Oct 30, 2012 8:18 am
Check starter circuit amperage draw when activating starter. Trapped water in a harness is a good conductor for electricity, in some cases can find open spot on wire and cause extreme draw.
khvann40
Post by khvann40 » Tue Oct 30, 2012 9:43 am
K-Mac I guess if I do this I need to hook a push button ignition up directly to the starter is that correct?
gblack15
Post by gblack15 » Tue Oct 30, 2012 10:27 am
Sounds like you are on to the problem. I would check the ground connections all the way to the battery. If you are grounded to the cage or stand you need to check and clean those connections. K-Mack has a good idea with the parallel ground cable.
khvann40
Post by khvann40 » Tue Oct 30, 2012 10:41 am
I have all of my grounds connected into a negative bus strap right by the battery and then a single negative cable coming off of that to the negative battery post. Also my ground wire is an 8 gauge wire should it be larger like 2 or 4? Keep in mind it worked fine like this b4 the sinking.
PM
Post by PM » Tue Oct 30, 2012 10:49 am
If you are using 8 gauge for your ground it is too lite. I am running 4.
15' Rivermaster (Hoffman)
Post by John Fenner » Tue Oct 30, 2012 11:06 am
Yould be surprised at how fast cables and wiring degrades while under water and the battery is still hooked up. Go get some new welding cable and terminals to replace all of the cables, you may want to go ahead and replace all switches as well as wiring, due to the rapid electrolysis that occurs in these situations. I personally would do a simple hot wire job to get the engine running and to temperature ASAP.
khvann40
Post by khvann40 » Tue Oct 30, 2012 12:54 pm
How do I hook up the push button ignition directly to my starter? One terminal to the starter ignition lead and the other directly to the battery?
glades cat
Post by glades cat » Tue Oct 30, 2012 1:21 pm
If the wire heated up, it's done.
Change it.
Don't guess on wire gauge or skimp on connector quality.
Here's a chart, or google it.
http://www.skytecair.com/Wire.htm
Post by John Fenner » Tue Oct 30, 2012 1:51 pm
khvann40 wrote:How do I hook up the push button ignition directly to my starter? One terminal to the starter ignition lead and the other directly to the battery?
Simply hook a lead to the batt lug where the cable hooks then through switch to the solenoid excite lead, you can run a switch off of the batt lead to the coil to get it running.
khvann40
Post by khvann40 » Tue Oct 30, 2012 3:34 pm
So starting to worry a little bc I can't get this thing turned over...hooked it up directly from battery to starter and when I hit switch starter clicks and makes humming noise. I can keep hitting switch and moves prop about 1/4" and then hums... Any ideas?
Post by John Fenner » Tue Oct 30, 2012 3:56 pm
Replace all cables?
Cutler
Post by Cutler » Tue Oct 30, 2012 5:09 pm
If you are hooking direct from battery to starter you wouldn't even be going through the switch
Post by John Fenner » Tue Oct 30, 2012 5:40 pm
Pretty sure he is referring to ignition switch/start switch. I hope to hear he replaced both positive and negative cables and hotwired this thing to life. Need to get that thing to operating temp soon!
khvann40
Post by khvann40 » Tue Oct 30, 2012 6:26 pm
Ok...so here is where I'm at. Hard wired the starter and went to crank and just click, click every time I push the ignition switch. Prop moves about 1/4" at a time. So started over from the beginning. Removed spark plugs and turned over manually to make sure no water was still in motor. Was a little stiff at first but after a few rotations of the prop now turns very easily. Used starter to then rotate faster and still turns very easy. Put plugs back into motor and back to where we were at. Starter won't turn the motor over and very hard to manually turn over by hand. Took valve covers off to inspect rockers and valves and everything seems to be working fine w plugs out but as soon as I put the plugs back in she binds up and won't turn... I'm stuck have no clue from here
Post by John Fenner » Tue Oct 30, 2012 6:29 pm
Battery cables have high resistance and won't deliver the amperage needed and need to replace them.
