billybob wrote:You need more than that. Need to sand it first then hit it with a sisal wheel with some hard polish that comes in bars.
Thats out of my league i'd have to pay someone to do that, if i touched it with a sander i cant imagine the outcome lol
Go on the ZEPHYR 40 site and buy one of their kits for polishing and follow the instructions, worked for me.
okay ill check them out! thanks!
JAKE, did you make them dual trolling motors like that or is that a kit??
No i did not they came on the boat, im pretty sure you can buy them as a kit but they are really expensive. If you are pretty crafty, im sure you could buy some trim tabs and make your own. If you ever get serious about it i can pm you more picutres of mine and you can get a better idea of that you need to do
Purple Polish and Deoxidizer.
I thought about purple polish before i started but already had this other stuff so i though id give it a try. Do you really think its gonna remove all those swirls? just curious? I dont mind buying it if its gonna work. Thanks!
we use sheep skin pads buffing out Lear Jets and boats, also a little flour will take the black specs out, slow down speed of the buffer, work small areas and keep a clean pad no matter what you use as a agent. Flitz, FLash, Metall, or any of the new stuff works well but takes time
Flour as in the flour you put in your food? that could possibly be my problem i did the entire boat with one buffing pad i definetely didnt keep it clean, i would do an area by hand but the electric buffer would do so much better i just did the whole thing with that and it was spinning full speed maybe that was part of my problem haha. I'll be sure and keep a clean pad, its just hard bc the boat was so nasty and neglected it only takes a minute before the pad is nasty. Thanks!
McGuire's makes a swirl remover. I have used it on my vehicles with amazing results. How well it would work on bare aluminum I have no idea. I do know it makes quick work of swirls on a paint job though.
Alright kajun next time i stop by the store ill read the label on the back and see what it works on, Thanks!
