0470
AirboatDon
0470
Post by AirboatDon » Fri Mar 08, 2013 9:27 am
I have a continental 0470 Dose any one no what the compression is in the cyl.
gruprgetr
Re: 0470
Post by gruprgetr » Fri Mar 08, 2013 9:50 am
if the motors not running................i would say none
if the motors crunkup and runnin..........who knows
saaftd............jmo :rebel: :rebel: :dontknow:
(SWAMP GAS)
IF YOU PISS SOMEONE OFF MEANS THEY HEARD YOU
AIRBOATS DONT SPREAD HYDRILLA
AIRBOATS DONT CAUSE ANIMOSITY- PEOPLE DO!!
PROTECT YOUR FUTURE WEAR A PFD AND VOTE!!
on a dark calm night ya can hear the cryaker scratchin on your poly
skinny99
Re: 0470
Post by skinny99 » Fri Mar 08, 2013 10:00 am
Are you asking what the static compression ratio is on a 0-470? You would need to know exactly what model you have to get an accurate answer and hope that it has never been modified.
Or are asking what the cranking cylinder pressure should be on a healthy 0-470?
AirHog
Re: 0470
Post by AirHog » Fri Mar 08, 2013 11:51 am
I have see GPU's run OK with 70 to 80 psi... But they were down on power and smoked
But idled well and ran ok
A fresh 0470 GPU conversion will have about 150 psi when broke in
This is on a warm motor with hot battery and throttle wide open.
And remember equal numbers are more important every gauge reads
A little different
True AC somebody will chime in but I think true AC will be 140 psi
Good Luck!
AirboatDon
Re: 0470
Post by AirboatDon » Fri Mar 08, 2013 12:47 pm
AirHog wrote:I have see GPU's run OK with 70 to 80 psi... But they were down on power and smoked
A little different
Good Luck!
Thanks for your help
AirboatDon
Re: 0470
Post by AirboatDon » Fri Mar 08, 2013 12:49 pm
gruprgetr wrote:if the motors not running................i would say none
TOO FUNNY
