hull jack settings
sseater
hull jack settings
Post by sseater » Wed Apr 24, 2013 10:13 am
so i ran my boat for the first time yesterday since i got it back together. its hopping really bad. i blindly set the jacks before going out all equally. i have 3 behind the tank and 3 in front of the tank. do i need to put more pressure on the front more than the back or the other way around? or all equal? i played with it while i was out there and just couldnt get it right... any advise is appreciated. i did a search on the subject and didnt find exactly what i was looking for.
Tony480
Re: hull jack settings
Post by Tony480 » Wed Apr 24, 2013 10:44 am
You have 6 jacks??? Or 2 jacks that push down on 3 t bars each?
farmboy
Post by farmboy » Wed Apr 24, 2013 10:54 am
Tony480 wrote:You have 6 jacks??? Or 2 jacks that push down on 3 t bars each?
I was about to ask the same thing...
sseater
Post by sseater » Wed Apr 24, 2013 11:10 am
yes 2 jacks, three t-bars each
aherr520
Post by aherr520 » Wed Apr 24, 2013 11:41 am
your going to have to play with the settings while your on the water, but you might need more then the jacks. If you have poly you can put some thin metal in between the hull and poly, should be an easy fix good luck with it
aaof member
farmboy
Post by farmboy » Wed Apr 24, 2013 12:31 pm
sseater wrote:so i ran my boat for the first time yesterday since i got it back together. its hopping really bad. i blindly set the jacks before going out all equally. i have 3 behind the tank and 3 in front of the tank. do i need to put more pressure on the front more than the back or the other way around? or all equal? i played with it while i was out there and just couldnt get it right... any advise is appreciated. i did a search on the subject and didnt find exactly what i was looking for.
I've never had jacks help for hopping I've used jacks to help free the boat up on the ground & water now I'm not saying they will not help on hopping just never helped for me. I would set the boat on some flat hard ground adjust down until the hull will rock side to side very little. Be carful if you go to far it will wear your bottom out fast in the middle. Look on the back of your hull and see if it has a lip on it. If so take a "dead blow" hammer and hit it where the chimes start to bend upwards just where it barely touches the ground. Just keep making small adjustments and you will get it right. Mine was bad at first stuck to the water & ground and hopped... I putt 3 jacks in it set them where I wanted them worked on that lip in the back now it doesnt hop at all even with 40gallons of fuel and 3 people in the back seat and its free on the ground and water. I hope this helps and good luck! Kevin
nebraskaairboater
Post by nebraskaairboater » Wed Apr 24, 2013 1:59 pm
If you have tension on the jacks take it out. In my experience on my boat as I added tension (pushed on the tbars) the nose came up. The more the nose came up the more it hopped. I would try that before getting too drastic. Start with no tension on the stringers and if it rides on the nose add tension until the just before it starts to hop. If it still hops check your engine angle with the stringers level. You want it level or a close with the stringers.
Dan Porter, Jr.
Fremont, NE
fishinfool64
Post by fishinfool64 » Wed Apr 24, 2013 4:06 pm
set it on flat ground take a hammer and flatten that lip where your trim tab is mounted all the way across get it somewhat flat if you push off on the ground alot it bends it up
and will make it hop
torque
Post by torque » Thu Apr 25, 2013 8:56 am
First of all, set your motor a little down in the back. that will bring the nosie up while running. The put it in deep water to set your jacks! The back jack should stay at neutarl an the front jack you should run it an start turning it down till you get it where you want it!! An if you jack the front one down an it starts hoping then tap your trim tab down or if you don't have one then back the front jack off a little at a time! jmo
Waggs
Post by Waggs » Thu Apr 25, 2013 10:21 am
torque wrote:First of all, set your motor a little down in the back. that will bring the nosie up while running. The put it in deep water to set your jacks! The back jack should stay at neutarl an the front jack you should run it an start turning it down till you get it where you want it!! An if you jack the front one down an it starts hoping then tap your trim tab down or if you don't have one then back the front jack off a little at a time! jmo
If you're calling the prop end the back, then this advise is incorrect. Bring the prop side up to bring the bow up.
Liberty Mechanical Services
321-689-7709
Making America Cool Again!
KCCO
Post by Deano » Thu Apr 25, 2013 2:13 pm
Sseater, Waggs is correct. Evidently, Torque unintentionally mis-spoke.
Trimming the prop end of the engine is just like trimming an outboard.
Trim the motor up . . . the bow comes up.
Trim the motor down . . . bow comes down.
