best thing to paint inside a fiberglass hull?
lotacarnage1
Post by lotacarnage1 »
I'm thinking grey bed liner. what is your opinion
smeller's the feller
billybob
Re: best thing to paint inside a fiberglass hull?
Post by billybob »
Gelcoat.
I do all my own stunts!!!!!!
BANANA BOAT
Post by BANANA BOAT »
Interlux makes a good paint called bilge coat. 1 part and easy to apply
HAMMERHEAD
Post by HAMMERHEAD »
WHATS WRONG WITH GEL COAT WITH WAX? ITS GOING TO BE THE TUFFEST!
boobidges
Post by boobidges »
Gel coat doesn't flex enough. Tends to crack and fall off. Best thingis high solid epoxy
CNichols
Post by CNichols »
Marine top coat roll on works great.
460 FULLTRACK
Post by 460 FULLTRACK »
I used Interlux black mixed with a dulling agent to make flat black. Most of the marine epoxy paints are a gloss finish. They roll on with a foam roller, so easy.
Gary S
Post by Gary S »
Gel coat doesn't flex? If it's falling off it is most likely because of preparation. It doesn't fall off the outside of the boat.
HAMMERHEAD
boobidges wrote:Gel coat doesn't flex enough. Tends to crack and fall off. Best thingis high solid epoxy
GELCOAT FLEXES AND BREAKS OFF BECAUSE IT WAS EITHER PUT ON TOO THICK OR THE RESIN WAS LEFT TO CURE TOO LONG OR IN AN OLDER BOAT THE SURFACE WASNT PREPPED PROPERLY. IF IT DIDNT FLEX ENOUGH THEY WOULDNT USE IT ON FIBERGLASS BOATS.
happy harold
Post by happy harold »
use gelcoat.
hooker
Post by hooker »
thats right or ur boat is to thin and old flexes to much time for new or different boat
