any comments on this design?
grey owl
Post by grey owl »
just wondering if anyone has any thoughts on this concept? it would probably not shine in the swamps but im thinking it would work well as a smaller boat for basic transportation in ice, snow, water.
PeaRiverOpossum
Re: any comments on this design?
Post by PeaRiverOpossum »
I like it. Beautiful build! I love the colors. What are the details on the motor and all that?
grey owl
Post by grey owl »
its not my build, a European design that I found surfing.
http://hydrokopteri.fi/index.php?pinc=3
the best I can tell its powered by a herth @50hp. I cant translate the page so details are limited to e pictures.
sorry I cant be more specific.
PeaRiverOpossum
grey owl wrote:its not my build, a European design that I found surfing.
ahhh I see. Open it in Google Chrome and it will translate it for you.
Alpal
Post by Alpal »
Sitting with your back to the icey wind while you toast your hands in the hot exhaust looks like a good idea in that climate...
gobblerD
Post by gobblerD »
The hull is interesting. The rounded back and it looks like it is foam filled? It seems made for that climate.
JAMES
Post by JAMES »
HOW U STEER WHERES RUDDERS
Bruce
Post by Bruce »
JAMES wrote:HOW U STEER WHERES RUDDERS
looks like the motor pivots
12 foot Mamba "The Underdog"
grey owl
Post by grey owl »
if you Google it a couple videos come up on utube "Hydrokopteri Kelirikko 420"
akblackdawg
Post by akblackdawg »
Pretty obvious that the whole thing pivots, cage and all, looks like a outboard style handle going forward into the guys lap, most likely a twist type throttle grip. That thing is cool, i would perfer my heated cab for running snow and ice, but if that hull is light, it would be a super light boat, if aluminum hull, and slick bottom of some sort, bet it would run dry if not loaded to heavy. Economical also to run. I could sell my boat and buy 10 of those, or close to it. Bud
PORTOBELO
Post by PORTOBELO »
That is an approximate translation of the text. ;)
grey owl
Post by grey owl »
thanks, I was just thinking for running around close to home something like that would save me cranking up the 540 whern cold but its also hard to justify two boats.
cheers will
akblackdawg
grey owl wrote:hard to justify two boats.
cheers will
The fuel economy of the small boat might be enough to justify, especially with the higher prices you have up there. Bud
Bob in Canada
Post by Bob in Canada »
I'd like to have one . In the videos it seems to handle and corner very well . Hull looks like it floats .
If I owned one I'd think about some type of a real seat . Doesn't look like much planning went into rider comfort .
Some type of windshield would also be nice .
This is just me but a four stroke version would appeal to me a bit more . I'm not a big fan of two strokes .
It seems like it would do the trick and be a lot cheaper to operate than my big boat .
14x8 Diamondback , 2.38-1 Stinger , 350 GM Marine , Sensenich 3 Blade "R" prop
akblackdawg
i think the big weakness in the design is that the only contact to support, strength, is the pivot where the motor/prop turns. That one point has to hold the entire weight of the engine, and the forward thrust. I would consider putting a light frame up to the top of the cage with a couple forward struts (headache bars) to give it strenth. Bud
grey owl
Post by grey owl »
I love the thought that you don't need the extra weight of the rudder but is it strong enough to endure the test of time. I live on an island and am going through freeze up right now so transportation is limited. the marina is 15 miles away so I would only ever use my 16/540 but for working around the bay the design appeals to me. Because it wouldn't be used as a novelty I seriously wonder how strong the mounting system is and if it can handle full time work use for the times of year it is required.
Bob in Canada
You'd find out that the mount system suffered from metal fatigue , stress cracks or failure due to the cold about 1/10 of a second after the running engine and prop flew past your shoulder .
I had an engine stand fail in my boat and it was just by the grace of God that I noticed it just before the engine and prop totally broke loose and the slice and dice began . It still turns my stomach when I think of how close my wife and I came it a nightmare event . ( Take a look at the pictures in my photos )
Cold weather can really play hell on steel .
rjbradlow
Post by rjbradlow »
Translation:
Hydrocopter
Hydrocopter (real name moottorireki)* is made of metal boats. Snow, ice and water flowing device allows for year-round movement
of water bodies, as well as in open snow-covered land areas safely.
Suitable for.
  • fishermen for use at work
  • for use at work
  • recovering the system, but also on thin ice.
  • travel and transport tool when other mobility equipment no longer work.
Fishermen have access to the device acquisition EU support.
Current soles made of Rymättylä Terhi boat. The dimensions 420x180x40. Helicopter with an approximate weight: 180 kg.
The base material of polyethylene plastic consumption.
Thrust equivalent to 3-blade carbon fiber propeller, which is used by 50hp HIRTH F23LW air-cooled 2-stroke petrol engine.
Engine Features:
  • electric and manual start
  • Electronic reliable CDI ignition ensure operation of the engine, even when the battery would go broke.
  • -maintenance Mikuni slide carburettors.
  • G23 V-ribbed belt drive.
  • the propeller blade angle to be adjusted.
  • 250w 12v electrical system power (lights, etc.)
  • propulsion 2-stroke-gas mixture 98E
Source: Google Translate http://translate.google.com (Finnish to English)
*moottorireki is actually two words:
Moottori: Engine
Reki: River
Terhi Boats ... Unsinkable !
http://www.youtube.com/watch?v=cSwumPiCN_U
Yeah, We've got those too...
http://www.bostonwhaler.com/page.aspx/p ... haler.aspx
