Best way to remove old poly bolts?
pipedog
Post by pipedog »
I have a project boat and have to remove the poly, and so far has been a real son of a BI##H!! The bolts are stainless with lock nuts and philips head most are painted over. I got some out some stripped some snapped and I have 2 million to go :banghead: ...I also cut some but those bolts ate up a blade in no time :dontknow: ...any advice,tips,tricks,type of blades,anything will be appreciated!
Thanks .. :thumbleft:
Palm Beach open hull 13'9" with 6.0 F.I. LS - Ox Box and a 3bld "R"
skinnypockets
Re: Best way to remove old poly bolts?
Post by skinnypockets »
pipedog wrote:I have a project boat and have to remove the poly, and so far has been a real son of a BI##H!! The bolts are stainless with lock nuts and philips head most are painted over. I got some out some stripped some snapped and I have 2 million to go :banghead: ...I also cut some but those bolts ate up a blade in no time :dontknow: ...any advice,tips,tricks,type of blades,anything will be appreciated!
Kyle, Have you tried drilling the bolts from the head end?
:rebel: :florida: :old_glory:
smessler34
Post by smessler34 »
I had the same problem.....i hit em with a propane torch, the a shot of PB blaster while they were hot , came right out....give it a shot,good luck
Bruce
Post by Bruce »
Back them off from the nut side
12 foot Mamba "The Underdog"
dougeey
Post by dougeey »
They make a bit to remove striped out Philips get it at Sears. Hold the head and use a batt.impack to turn the nuts.
pipedog
Post by pipedog »
Haven't tried that yet, but that should work! I just tried a sawzall with a fine toothed blade called the torch and that worked pretty good, that blade lasted awhile.
pipedog
Post by pipedog »
smessler34 wrote:I had the same problem.....i hit em with a propane torch, the a shot of PB blaster while they were hot , came right out....give it a shot,good luck
smessler I should of mentioned that it if a fiberglass hull, so I'm afraid to put heat to it. Thanks for the input :thumbleft:
dougeey
Post by dougeey »
Are you trying to save the poly. If not you can grind the heads off on poly. Side
pipedog
Post by pipedog »
Bruce wrote:Back them off from the nut side
Hey Bruce I've tried ratchets, breaker bar's, electric impact, I just can't hold the philips head without stripping it :dontknow: ..So far the sawzall is the best, but I just started and have a sh!t load to go. I'm going to try drilling in the philips head next.
Thanks
pipedog
Post by pipedog »
dougeey wrote:Are you trying to save the poly. If not you can grind the heads off on poly. Side
Hey Dougeey the poly is shot-out, so that is a damn good idea also :thumbleft: .. I did use a thin cutting wheel to cut the bolts, that worked good but ate-up the blades quick. I have a thick grinding wheel I can try :salute:
Thanks
dougeey
Post by dougeey »
Thanks
Your welcome if I still lived in wpb I would come over and help but got to many people living there now!!!
terrible ted
Post by terrible ted »
well put your air gun on the nut and snap(tighten)as many as you can first. Stainless is soft not that hard.
barhopper
Post by barhopper »
I agree with Bruce and Ted. I've always used a impact wrench on the nut side with pretty good results. You'll always have some stubborn ones that require more effort. Will grinding them off on the poly side make the bolt hot enough to damage the fiberglass?
TheElevatorGuy
Post by TheElevatorGuy »
Hey Kyle........I have the quickest trick to get rid of all of the bolts at one shot................sell the hull :lol: :lol: :lol:
pipedog
Post by pipedog »
pipedog
Post by pipedog »
pipedog
Post by pipedog »
pipedog
Post by pipedog »
pipedog
Post by pipedog »
Tony480
Post by Tony480 »
Wow!! Not even the correct poly bolts....some people amaze me...
pipedog
Post by pipedog »
Dark thirty but got it done!! some came off with the impact on the nuts like bruce said, tried that first on most, some would spin. Then I would put a breaker bar on the nut and use a drill with a philips bit and get some like that, if it stipped then I would grind, drill, sawzall the philips head off. It took alot of BEERs to get the job done but it was worth it :drunken: ...Thanks for all the input !!! :salute:
Airboat_Fever
Post by Airboat_Fever »
i used an air impact on the phillips side and dad was on the inside with a socket and a wrench it worked pretty good but it definitely requires 2 people.
When No one else can get out I CAN!
___________________________
The VERY FIRST 13' Fiberglass AIRGATOR with Direct Drive Smallblock Chevy 72-32 paddle
in the works 10' 6in. by 7' Apache hull with 4.3 Direct Drive
Hog Guts
Post by Hog Guts »
Fire that up in the tree... Could be fun :)
pontoon outlaw
Post by pontoon outlaw »
:scratch: WTH were those round head screws?? no wonder they were a bear, def rounded the threads down over time and insult to injury they used 2 peices of poly instead of just one whole sheet :violent1: good job man when I did mine the first time it had the old white poly on it, was brittle as hell, hammer and chissle to get poly off then vise grips on the stubborn bolts :thumbleft:
Birddog247
Post by Birddog247 »
Damm man
looks like you got a lot done. :thumbleft: you still want that sheet of poly I got?
12ft Palm Beach
stock 350sbc
2.1 gear/80"NGR
"Save a tree; eat a beaver"!
