Spray tank liquid
Ronaldregan
Spray tank liquid
Post by Ronaldregan »
Beside diesel what is the slickest liquid for a spray tank
radtech
Re: Spray tank liquid
Post by radtech »
Ronaldregan wrote:Beside diesel what is the slickest liquid for a spray tank
A lot of people just use soap and water
midnight rider
Post by midnight rider »
Liquid polymer. Nothing slicker when diluted.
Ronaldregan
Where do u get liquid polymer
dougeey
Post by dougeey »
What ever you use make sure it is biodegradable and you can prove it . FYI ATF is the best stuff the BCSD runs with it but won't admit it!!!!!!! Thanks. Doug. Oh tire shine works real good too!!!!!!
billybob
Post by billybob »
Any driller supplier sells it. The slickest stuff we use doing directional bores is EZ mud by Baroid. Stupid slick.
I do all my own stunts!!!!!!
midnight rider
I've tried that ez mud. Very slick but still not quite
There with liquid polymer. I get it at Helena in immokalee
rjonesboy
Post by rjonesboy »
Surfactant. Makes water wetter. designed to break surface tension between two liquids or a liquid and a solid. Lots of applications, but commonly found at landscape supply stores (lesco/john deere) or chemical suppliers
digginfool
Post by digginfool »
EZ Mud is slick but it increases viscosity. Makes pumping harder. I would go along with a surfactant as well. There are plenty of drilling additives that are slick but to use them at a concentration that is low enough that your little Shur-Flo pump will push it probably wouldn't be effective. BTW, I'm a bit of a directional driller myself. Just a little company doing little bores. ;) I do plan to experiment with some of the additives we use but my gut instinct tells me that it's going to be way too expensive for the average joe to go buy it.
billybob
Post by billybob »
digginfool wrote:EZ Mud is slick but it increases viscosity. Makes pumping harder. I would go along with a surfactant as well. There are plenty of drilling additives that are slick but to use them at a concentration that is low enough that your little Shur-Flo pump will push it probably wouldn't be effective. BTW, I'm a bit of a directional driller myself. Just a little company doing little bores. ;) I do plan to experiment with some of the additives we use but my gut instinct tells me that it's going to be way too expensive for the average joe to go buy it.
What size rigs do y'all run? What are you installing? I have always just used the EZ mud. A gallon last a year in my old boat. Just back it down a little bit and it would get it done. I was pumping it with an MSD high pressure fuel pump. Just don't leave it in the tank, it will couagulate.
digginfool
Running a DD210, 7020, 2720 Mach 1 and two regular 2720s. We do water and sewer almost exclusively.
Whitebear
Post by Whitebear »
Depending on what State you are in, some things can be illegal, and get you arrested. Be sure to check and double check in your own State before spraying. :idea:
billybob
Post by billybob »
digginfool wrote:Running a DD210, 7020, 2720 Mach 1 and two regular 2720s. We do water and sewer almost exclusively.
Not to high jack this post but that American Auger is a beast. We do water and sewer also. Do all of our in house stuff. Sub the bigger stuff out for now. PM me sometime man, wouldn't mind talking a little bit.
TheElevatorGuy
Post by TheElevatorGuy »
I personally like to use the industrial size personal lubricant......I send the wife to pick it up at the store and she gets all excited till she returns and watches me pour it into my boat...........she got furious and said, "Why did you do that? Are you gona go make love to that thing now?"
I said, "No, that's for later when I hit that dry hole!" :lol: :lol: :lol: :lol: :lol: :lol:
swampfox
Post by swampfox »
I pull fiber optic cable fer a living. We use cable pulling lubricant called whoop ass. Picture of a big g donkey on it. Biodegradable and last through friction. Easy to dilute. Easy to spray with right tip.
Diamondback 0235c sprayer/ predator gore and powerplant??? Stroked out 65 continental :)
Duece
Post by Duece »
I use Simple Green and water. Pretty slick and is biodegradable. I had that liquid polymer clog up a pump of mine and burn it up. Since then, gone w/Simple Green. You can prove SG is biodegradable if you have the bottle with you (says so right on the label!).
Duece
"Welcome to the Dark Side..."
Birddog247
Post by Birddog247 »
Poly control 2 slicker than a honeymoon prick
12ft Palm Beach
stock 350sbc
2.1 gear/80"NGR
"Save a tree; eat a beaver"!
eagal69
Post by eagal69 »
Mr Bubbles works good too
I don't follow trails I make them, 15 x 8 Alumitech,496 Stroker bbc,2.3-1 belt drive 82" 4 blade R.
KRVSA
Waggs
Post by Waggs »
Round up
Liberty Mechanical Services
321-689-7709
Making America Cool Again!
KCCO
radtech
Post by radtech »
Waggs wrote:Round up
:lol:
Waggs
Post by Waggs »
:lol:
It's biodegradable!!!
321-689-7709
KCCO
midnight rider
That poly control 2 is the same as liquid polymer. They are great just dilute them to the consistency of water. They way they don't clog Up the pump. They are a
Sinker and drift retardant.
midnight rider
If somebody knows how to get a pic on this forum I just put a pic of the stuff in my gallery
Whitebear
Post by Whitebear »
midnight rider wrote:If somebody knows how to get a pic on this forum I just put a pic of the stuff in my gallery
Open your pic to the big pic. Not the Thumbnail size. Right click it and pull down to copy image location. now go to your post either a new post or edit an existing one. Left click the IMG button, now right click and pull down to paste. Move your cursor away from it and Submit, your done.
midnight rider
Thanks white bear but unfortunately I'm on an iPhone
