Down and out need 5/16 polymer can't find it anywhere!!!!!!!
2WHEELER
Post by 2WHEELER » Sun May 18, 2014 10:33 pm
Does anyone have any 5/16 poly for sale or know where i can get some?? Thanks
Sorry I accidently wrote 3/16 it was late at night I know 5/16 is pretty common
sseater
Re: Down and out need 3/16 polymer can't find it anywhere!!!
Post by sseater » Mon May 19, 2014 8:08 am
Have you tried hamant or alumitec?
Post by SWAMPHUNTER45 » Mon May 19, 2014 8:41 am
Why not run 1/4 inch it is everywhere
Tony480
Post by Tony480 » Mon May 19, 2014 9:23 am
Never seen anyone sell 3/16 poly...
Post by Deano » Mon May 19, 2014 9:30 am
Tony480 wrote:Never seen anyone sell 3/16 poly...
x2
Last time I was checking, GTO had 1/4 and 3/8 in stock to walk out with.
That Caddy wouldn't know the difference anyway . . . :)
scottyroll
Post by scottyroll » Mon May 19, 2014 9:36 am
Yeah, you pretty much have get 1/4" and ride it until it turns into 3/16 if that's the size ya want :bom:
:Scotty-Roll:
FLAwless
Southern Style
Re: Down and out need 5/16 polymer can't find it anywhere!!!
Post by Southern Style » Mon May 19, 2014 8:51 pm
Don't think 1/16 of an inch difference would be noticeable AT ALL even if they did make it.. Just get the 1/4 inch.
KRVSA Member
SJRAA Member
KCCO
FFCDraper
Post by FFCDraper » Thu May 22, 2014 5:29 pm
I bought 5/16 from GTO not to long ago.
Sawgrass150
Post by Sawgrass150 » Thu May 22, 2014 7:12 pm
A customer of mine got a sheet of 3/16 poly White with a blue strip in it from horn plastics But I'm not sure of what it's durability is I do know it is already spider cracked at one year old
terrible ted
Post by terrible ted » Thu May 22, 2014 7:31 pm
http://www.farcoplastics.com/
I bought my sheet from Farco plastic last time i needed some.
Prototype
Post by Prototype » Fri May 23, 2014 9:47 pm
Think about all the work to weight ratio of 1/4 inch to 3/8 good poly. Yes your pushing a few more pounds but floating a fragment higher. Pick a good poly because I just had one pull a screw like wax in the heat. Totally disgusted it pulled a good fit counter sink and had to counter sink two on each side of it.
It was a local brand too which is really bad for there rep to be gator tough.
Post by SWAMPHUNTER45 » Sat May 24, 2014 8:54 am
We had a screw pull thru during install on 3/8 and it was a huge pain in the butt to remedy and reset. Kind of my fault I think was working to bend the edges and may have warmed it a little to much and then put the gorilla grip on it. I'd suggest not trying to radius curves with 3/8 if you use it. Opt to armor the flat pad and leave the rest to chance.
Prototype
Post by Prototype » Sun May 25, 2014 6:46 pm
Swamp
I've contoured some wicked curves with heat and even relief cuts and double bolted 3/8. The new local stuff seems to need the old sidewalk bolts just to hold it down if its facing the sun with light upward stress to it. It even felt good drilling and counter sinking but a couple days in the sun it still pulled a screw. Maybe it's made for aluminum applications or fender washers?
