Power pole hydraulic 5/16 hose connector question
MacGyver
Post by MacGyver » Sun May 25, 2014 4:22 pm
Not sure how it happened but the one of the hoses blew off the bulkhead hose connection. It looks to be a pushin connector. I checked the hose diameter with my micrometers and it mic out at .315 OD . Is .315 hyd plastic hose a odd size maybe special to powerpole or can I get it local ?Part of the plastic fitting is missing. Can this be changed to brass connector ? Thanks for any advice . I cant find my manual either not sure what type of hyd oil I will need to top off the tank with either. Thanks for any help.
Steve
MacGyver
Tater Nutz
2012 15 x 8 ALum GTO w2ft grassrake
383 stroker 463 HP with stinger 255 to 1 soft drive
Sensenich 3 Blade 80" R series
yobee
Re: Power pole hydraulic 5/16 hose connector question
Post by yobee » Sun May 25, 2014 4:40 pm
I am not familiar with powerpoles at all, but if it is hydraulic any truck place or hydraulic house can more than likely make you a new hose. Probably not until Tuesday though lol.
Prototype
Post by Prototype » Sun May 25, 2014 5:29 pm
If its really funky, Amazon in Tampa can probably fix you up too. They have about everything if you need to replace a hose made from two different continents and manufacture from a third if your in a hurry?
midnight rider
Post by midnight rider » Sun May 25, 2014 6:34 pm
Which piece are you talking about. I've installed a few power poles. I have some tubing
Lengths left over. None of the ones I've installed have had a plastic fitting. Only brass.
MacGyver
Post by MacGyver » Sun May 25, 2014 8:29 pm
These are plastic fittings, I will chase down some brass fittings next week. Was just wondering if the 5/16 OD tube size was a odd size
MacGyver
Tater Nutz
midnight rider
Post by midnight rider » Sun May 25, 2014 8:36 pm
Ok. Well I have plenty of tube if you need some
MacGyver
Post by MacGyver » Sun May 25, 2014 9:41 pm
Thank you very much, hopefully I can just get new fitting :)
MacGyver
Tater Nutz
Post by One Eyed Gator » Tue May 27, 2014 7:49 am
Steve try Central hydraulics just past Miller Marine.
NW 58th Lane.
