Belt drive to Gear box
RONNIE JR.
Post by RONNIE JR. » Mon Aug 04, 2014 11:22 am
Looking for a little advise. I recently changed motor in my boat and went from a belt drive to a gear box. The problem I am having now is that my props are inside my boat approx. 11 inches. I was thinking about raising my motor a few inches and maybe cutting 2 inches out the transom. Any advise would be high appreciated. Many thanks in advanced.
muffled500hp
Re: Belt drive to Gear box
Post by muffled500hp » Mon Aug 04, 2014 11:52 am
What kind of prop are you running?
Keith ~~
Modern Performance Engines, LLC
Custom built engines for airboats, hotrods, mud trucks, buggies, circle track and drag racing!
352-282-6407
MPEKeith@gmail.com
www.facebook.com/modernperformanceenginesllc
RONNIE JR.
Post by RONNIE JR. » Mon Aug 04, 2014 12:20 pm
I'm running 80 inch sensenich S SERIES. I have plenty of room at the top of cage. I went from a 496BB to a 572BB. I went to gearbox because of the torque.
Post by :) » Mon Aug 04, 2014 1:39 pm
I'd say run it like it is. Seen a pile of boats with props down that much. Try it b4 u start cutting! Hope u switched blades.
Post by :) » Mon Aug 04, 2014 1:40 pm
Belts and gears turn opposite directions
junglecat
Post by junglecat » Mon Aug 04, 2014 3:12 pm
I run mine 10 inches deep into hull , angled transom and its 1 1/2 past bottom of transom . Try what you have first , maybe pretty close.
Larry Smith built 427 SBC
2.68 Ox Box
82" 3 blade R
PeaRiverOpossum
Post by PeaRiverOpossum » Mon Aug 04, 2014 3:17 pm
RONNIE JR. wrote:I'm running 80 inch sensenich S SERIES. I have plenty of room at the top of cage. I went from a 496BB to a 572BB. I went to gearbox because of the torque.
Not sure I understand this 100%. I assume you mean the belt won't handle the torque?
ptillman
Post by ptillman » Mon Aug 04, 2014 3:35 pm
junglecat wrote:I run mine 10 inches deep into hull , angled transom and its 1 1/2 past bottom of transom . Try what you have first , maybe pretty close.
Mine is set up the same as Junglecat's :thumbleft:
2014 14x8 JB Hull,421 SBC, Rotator 2.68:1, 82" NGR
12' Thurman, o470 angle valve, 72" WhirlWind Prop (SOLD)
13' Hamant, 383 Chevy, Blue Lightning Drive, 80" R 3 Blade (SOLD)
muffled500hp
Post by muffled500hp » Mon Aug 04, 2014 6:38 pm
Let it ride!
Keith ~~
352-282-6407
MPEKeith@gmail.com
