Boat is dipping in the back right?
RufflingFeathers
Post by RufflingFeathers »
Now that ive pitched my prop to 3 it seems like my boat is dipping to the right a little more then it used to. Is it because of the more pitch or do I need to " loosen" the bolt for the drive unit on the right and let the right side come up a little more or?
Ruffling Feather's one bird at a time....
Ruffling Feather's Guide Service
Capt. Brandon Kendrick
rufflingfeathers@yahoo.com
https://www.facebook.com/RufflingFeathersGuideService
936-671-3477
16ft Alumitech sb350
Re: Boat is dipping in the back right?
Post by Deano »
Sounds like torque roll to me. Must be a belt drive, right?
If that is the case, shimming the engine and/or drive will not make any difference.
Shifting some weight to port may help a little, but it may not.
Then get used to bracing yourself, or learn to stab it softly.
Or better yet, do all of the above.
fl cracker
Post by fl cracker »
More pitch means more bite which is going to cause more torque roll.
" I have two guns...
One for each of you "
2011 Al David / AV 540
yobee
Post by yobee »
You'll learn to give it the right amount of rudder to help with it, but hp and big blades are gonna twist lol.
