Go Right to Avoid Collision
Ol Yeller
Post by Ol Yeller »
Can we all agree that when airboating in the U S we should alway go right to avoid a collision with another boat? Never ever, no matter what, go left!
If you can't go right, go straight and hope and pray the other guy goes right.
If we almost collide and you go right and get stuck, I promise I will take the rest of the day to help unstick you and won't leave.
This rule is a must for airboaters because most of us can't hear anything while running. So when two boats meet at a corner or narrow trail with little visibility there's not much time to think. The stay right rule might just help.
junglecat
Re: Go Right to Avoid Collision
Post by junglecat »
Never wrong if you both go right
Larry Smith built 427 SBC
2.68 Ox Box
82" 3 blade R
justin m
Post by justin m »
junglecat wrote:Never wrong if you both go right
X2
A/V 540 on a 13ft Navigator hull, swingin a 72" 2 blade WW signature series. Go boat, not a show boat.
terrible ted
Post by terrible ted »
My instincts would be to pull the rudder stick back. Just doesn't seam right to push out bringing your body out of the seat more. I don't know that normal but i tend to think your faster at pulling back instead of pushing out. I would think a normal reaction is to pull back? So whats your normal reaction?
Really were talking not thinking just reacting what would be your normal reaction?
For me i say it right now going right would be a hesitation just an unnatural reaction. Don't need to be flying down trails anyways just fast enough to stay on plain.
JCGator
Post by JCGator »
terrible ted wrote:My instincts would be to pull the rudder stick back. Just doesn't seam right to push out bringing your body out of the seat more. I don't know that normal but i tend to think your faster at pulling back instead of pushing out. I would think a normal reaction is to pull back? So whats your normal reaction?
I hear ya! It is not natural to push forward or hit the gas in an eminent collision so i just try to keep it on the front of my brain when going around blind corners and tight trails. Also i wear electronic earmuffs so i can slow down in a trail and at low RPM's the microphone turns back on and i can check. these were only $30 or so at bpro. I tend to be able to see someone coming from their prop blast scaring birds and sending vegetation in the air! no perfect system but everything helps. and lastly, SLOW DOWN & SLIDE SAFE! 8)
10'6" Taylor Hull. Lycoming 170 hp - O-320 w/ 480 AV jugs
JCGator
Post by JCGator »
Oh yeah and also get uninsured boater coverage in your boat insurance... I only have liability insurance for mine and at $100 a year it helps me sleep at night... :thumbleft:
KR23
Post by KR23 »
That’s the problem, inexperienced boaters don’t think and experienced boaters due. If you have situational awareness you can watch a situation develop even if you only have seconds, and an experienced boater isn’t going to go flying around a blind curve. All it takes is a little thinking, and experience to give yourself muscle memory for the right situations. Of course accidents due happen.
DDSBC
Post by DDSBC »
I've always heard push away or go right to avoid an oncoming boat. This works for me no matter what speed because I run an AC motor with no gear box so no matter what speed I'm going when I mash the gas the boat rolls to the right side and lifts the lefts side making right turns easier. I was out on Saturday and saw CM boat that torque rolled to the left so bad when he mashed the gas I'd think if he pushed the stick forward and floored it he would do a high side roll.
Micah Smith
BCAHCC, KRVSA and lifetime NRA member
12x7 Diamondback w/ rivited on poly, double rear driver double front passenger, full cage, 285 hp IO-520 swingin a 74" Whirl Wind Whisper Tip.
gso480jr
Post by gso480jr »
I always say go right on an encounter in trails. Just operate the boat in such a manner that both could come to an idle when in sight of each other. Yes that means off plane in corners, sorry. We all want to be able to see another day on our airboat!
diamondback0320
Post by diamondback0320 »
PUSH RIGHT not left,natural reaction pull left? Bullshit!!! I would run up in myrtles or whatever to avoid a airboat collision,rather b bruised up from some limbs then b hamburger from a prop!
diamondback0320
Post by Deano »
I can not believe what I am reading !!! :shock:
-[ Flame Proof Suit On ]-
one guy wrote:My instincts would be to pull the rudder stick back. Just doesn't seam right to push out . . . i tend to think your faster at pulling back . . .
another guy wrote:I hear ya! It is not natural to push forward or hit the gas in an eminent collision . . .
Turning to the right is akin to going to the shoulder of the road,
and the fastest way to turn an airboat is to accelerate while you are doing it.
Turning left is the same as saying "When in doubt, steer into oncoming traffic". :slap:
If common sense, historical precedents, and what everyone is taught are not enough for you consider this:
You will NEVER convince me, the FWC, the court system, and/or a jury that you acted responsibly if the other boat 'went right' and you did absolutely anything other than that.
Liability has gotten to be an ugly word, but is the reality in the world in which we live.
If you value your toys, home and family's well being as much as I do mine, you should practice accelerating to the right and always leave yourself room to do so. I you can't leave yourself that much room, it may be time to consider if you really need to put yourself in that position :idea: .
I try not to jump on the soapbox, but I have personally been nearly run down twice over the years after I went to the right and the other boat did not. Both times it was as if the bastard was trying to run me down. There is a narrow part of the local river here that I never run anymore just because the weekend warriors don't know which side to be on. And don't think weekend warriors don't take days off and go boating during the week either.
There is no substitute for seat time and practice. If turning right and/or accelerating is not reflex, and requires conscience thought to overcome some nonsensical instinct, then a person needs to be getting quite a bit more of both (seat time and practice).
-[ Rant Off ]-
radtech
Post by radtech »
I agree, Deeno. I can't say I'm a lifetime airboater or as experienced as some, but operating the stick has become second nature for me, to the point that it requires no actual thought. Avoiding obstacles or other boats is relatively easy. If your instinct isn't to turn right to avoid another boat coming at you, you definitely need more experience
diamondback0320
Well said deano,just last tues took the lady for an afternoon ride & as we had 1 more stop to make on our route b4 the ramp was on a skinny reed trail & as soon as it opened up & I went ta round a corner bam theres a rake comin around I go to push right & guess what the other boat goes left cut rt across my bow so I pull bk left to avoid,this same scenario happened last yr on opening of black powder to a buddy of mine which ended up in a wreck,my buddy goes right the other boat goes left,his 13yr old son was airlifted out but is ok,couldnt believe I was reading these responses either!
keebo
Post by keebo »
Inexperienced is right on time, the last yahoo I met in a corner went left instead of right and it was close. Go right, that straght crap don't work either, last one did that hit me and I was the one f@@@ up. Go right go right go right, get the experience to make it natural, save yourself and everyone else you may meet in a trail. First hand, while everyone has to learn try not to do it at the expense of injury to others, a chunk of prop in the back sucks, so if you don't have the boating skills take a class and learn the rules, whatever feels more natural to you for steering by all means set it up that way so you are comfortable, it only takes a second to change life forever.
:old_glory: :florida: :GA:
BluByU2
Post by BluByU2 »
NEVER PULL THE STICK, AND GO LEFT if you're facing a collision! That will get people killed! I've said this before also; If you are running along the shoreline, around blind curves, and the shore is on your left (port) side, you better leave enough room for another boat to pass between you, and the shore because the oncoming boat won't have anywhere to go except into the woods. Rules of right of way are the same for all vehicles, and vessels.
Stewie
Post by Stewie »
I can't believe what I'm reading either I'm in:shock: I PRAY TO GOD! ONE GUY & ANOTHER GUY ""NEVER MEET IN THE SAME TRAIL"" :violent1: or meet any other airboat in any trail!!! Lord help the :tool: that ever turned left when I turn right to avoid a collision in the trail!!!
Bruce
Post by Bruce »
pullin the stick back is second nature?!?!?!?!?! good god you mean i been doin it wrong all the these years hmm...
12 foot Mamba "The Underdog"
jeepinocala1111
Post by jeepinocala1111 »
JCGator wrote:Oh yeah and also get uninsured boater coverage in your boat insurance... I only have liability insurance for mine and at $100 a year it helps me sleep at night... :thumbleft:
What insurance company do you have?
Southern Style
Post by Southern Style »
RIGHT RIGHT RIGHT.... Never had a head on collision in tight trails because I (and every other airboater) has followed this simple rule.. And then came the day in middle trail (by tomato ditches) when I went RIGHT and the SOB went LEFT... Yea, we smacked broadside to broadside.. Scarred the wife to the point she was crying..
RIGHT RIGHT RIGHT... PLEASE, GO RIGHT...
KRVSA Member
SJRAA Member
KCCO
junglecat
Post by junglecat »
No wonder there are so many near misses anymore. You both turn right and NO ONE CROSSES the others' path. Pulling back , turning left feels more natural? …… turning board side in front of an oncoming boat feels natural.
Get in the boat by yourself and practice evasive moves to the right till it becomes second nature , then you will be ready to have passengers.
2.68 Ox Box
82" 3 blade R
nomad41
Post by nomad41 »
It's call rules of the road. It's a law to turn right. Ask the coast guard. You will be charged if you turn left and cause an accident
Treasurer FAA
Svcliche@yahoo.com
Bubba
Post by Bubba »
nomad41 wrote:It's call rules of the road. It's a law to turn right. Ask the coast guard. You will be charged if you turn left and cause an accident
DING DING DING we have a winner!
FLIRTIN WITH DISASTER
Post by :) »
If everyone is riding on the right side then go right would just be the way I wanted to go.. I never been in a real pinch before. I'm never in a big hurry to get anywhere and I like to think I always look way ahead. I know this stuff eventually happens to most of us, I just been lucky so far. Now if ur on the right side and somebody comes from the other way on ur side I'm sure it's hard to go right if if don't look right in the moment.
terrible ted
Yes it is but i saying in an actually situation your instincts may take over seen it before. Experience in the heat of the moment for some wont matter.
I got My first boat i got in 1980. If you flying down trails your the problem no matter what.
