prop dilemma
SSR1320
prop dilemma
Post by SSR1320 »
I have a 13' DB ultra light with O540 straight valve spinning a 3 blade H. I wanted a 2 blade NGQ but it wouldnt fit would have to move everything forward 2-3". I put on a 72 whirlwind wisper tip and tried it out friday for the first time but didnt really feel any significant difference from my H. We did have a 20 knot headwind. sure that doesnt help in any kind of testing. Had some other issues that I need to fix and then try it again hoppefully on a less windy day. I'm just not sure if its worth $$$$ the change. Any help, suggestions, comments and/or opinions would help, thanks
13' Diamondback ultralight s/v O540 NGQ
fl cracker
Re: prop dilemma
Post by fl cracker »
You can always cut the Winglet off of the NGQ.
" I have two guns...
One for each of you "
2017 Al David / stroked LS
ptr34
Re: prop dilemma
Post by ptr34 »
Thats not issue cracker. Winglet doesnt stick out more than a regular Q. Sounds like metalworks is real close to back of boat
tons videos on YouTube ptr34
Rich Andrews
Re: prop dilemma
Post by Rich Andrews »
Get an old signature series if u want a prop that will pull like a mule,and not ding up if a twig hits it.
fl cracker
Re: prop dilemma
Andrew, this one is going on a airboat so it needs to push lol
Re: prop dilemma
Post by Deano »
Rich Andrews wrote:Get an old signature series if u want a prop that will pull like a mule,and not ding up if a twig hits it.
x 2
Tony480
Re: prop dilemma
Post by Tony480 »
If an h fit than there's no reason an ngq wouldn't
Rich Andrews
Re: prop dilemma
fl cracker wrote:Andrew, this one is going on a airboat so it needs to push lol
Sorry, I used to pull Lycoming guys all the time with my old 470...my bad LOL
wildman9
Re: prop dilemma
Post by wildman9 »
I call bs u r going too far now. I'd have too see that to believe I have a 180 that would've pulled that 0470 and that car barge u have.
ptr34
Re: prop dilemma
Post by ptr34 »
Depends tony on how close it is to transom.
SSR1320
Re: prop dilemma
Post by SSR1320 »
It does hit the transom
fl cracker
Re: prop dilemma
What hits? Winglet or trailing edge?
fl cracker
Re: prop dilemma
I would think a 68" NGQ would fit.
BRMaynor
Re: prop dilemma
Post by BRMaynor »
Terry/All - How does the winglet not stick out any further than the Q? I guess you could call this measurement the height of the blade and I would think the NGQ has to be taller with it's winglets versus a Q or H or any other blade without the winglets right?
Seeing nothing but positive reviews about the NGQ has me considering it over my Q but I am also concerned with having to move everything foward as well. Was only planning to leave 3-4" of space between the prop and transom as I want a safe distance there but also want the motor back as far as possible in the hull. If the NGQ requires more space, I would hope it's performance is worth having the weight further forward in the boat... Maybe I'm splitting hairs here regarding weight and the matter of a few inches but how much taller is an NGQ than a Q?
"The Constitution shall never be construed to prevent the people of the United States, who are peaceable citizens from keeping their own arms . . ."
- SAMUEL ADAMS
Hog Guts
Re: prop dilemma
Post by Hog Guts »
I have two blades you can install on your boat to check while I have them off my boat. The length is measured to the winglet tip so length is accurate and I believe the whole prop is swept in such a way that the rear of the winglet isn't just sticking back further than another prop - at least not the whole difference. You should call me and just try it while you have the chance I think you live 3 miles away.
SSR1320
Re: prop dilemma
Post by SSR1320 »
I'm going testing again today hopefully the wind won't be an issue bc its been blowing pretty heavy all week down south
SSR1320
Re: prop dilemma
Post by SSR1320 »
Lighter wind today still didn't feel much difference in the whisper tip to my 3 blade h not much if any quieter just a little mid range but not enough to warrant the change I was getting about 2550 - 2650 rpm with the wind and against it is that what it should be???
sidejobs
Re: prop dilemma
Post by sidejobs »
You need to turn that whisper tip 2800-3000. Then you may see a difference.
________________
IDIOT !
lariat
Re: prop dilemma
Post by lariat »
I've tried several different props on my boat and have found some subtle differences, but nothing earth shattering with any of them. Here is what I've run. 5 blade warp, 3 blade NGH, 5 blade Sabre, 2 blade NGQ, 6 blade staggered Sabre, and just today tried a 3 blade Q. The biggest difference I found was the noise differences, and some pushed a little better at different RPM ranges, but non of them have been heads and shoulders above the rest. All around, I like the 6 blade staggered the best, and probably liked the NGH the least.
SSR1320
Re: prop dilemma
Post by SSR1320 »
Just wouldnt get that rpm
sidejobs
Re: prop dilemma
Post by sidejobs »
Why couldn't you get that rpm ? It's adjustable ..........
________________
IDIOT !
SSR1320
Re: prop dilemma
Post by SSR1320 »
It gets 2800-2900 rpm on the trailer
sidejobs
Re: prop dilemma
Post by sidejobs »
That's good. You should gain a lil on the water. It must have been hurricane winds to drop you 3-400 rpm :shock:
________________
IDIOT !
Striker543
Re: prop dilemma
Post by Striker543 »
It's getting 28-2900 on the trailer but only 2550-2650 on the water? Something isn't right there. If anything you should gain another 100 rpms or so on the water compared to on the trailer.
