12ft hull vs 13-6
Hog Guts
12ft hull vs 13-6
Post by Hog Guts »
Other than the obvious foot and a half, what changes with the feel / handling of the boat?
How much heavier? Does increased surface area help or hinder on the hill?
My existing hull is 12ft. It's 7-4 across the top and 6-8 on the bottom rear transom flat area. Looking at another hull but would be 13-6 and few inches wider top but not bottom (would have rounder corners my existing is 90deg from side to bottom.
Looks like either hull will have 540 260hp
Thanks
dodobird
Re: 12ft hull vs 13-6
Post by dodobird »
i myself think wider n longer but not to long is better on the ground its like takin a piece of plywood and standin it on end and try to push it then lay it down flat and push it ull push it on the wider side easier :florida: distributes weight better JIMO
13' laser 360sbc oxdrive 2.68 .... 80" 3 blade whispertip ex :florida:
scottyroll
Post by scottyroll »
Hog Guts wrote:Does increased surface area help or hinder on the hill?
More surface area = more drag.
:Scotty-Roll:
FLAwless
sidejobs
Post by sidejobs »
Less surface area = more pressure psi
It's all about the set up. I like a 13 better than a 12 but it depends on your entire set up/engine combo. I believe you will like the 13 6 a lot more for what you're gonna do.
________________
IDIOT !
Andrew McD
Post by Andrew McD »
Something to consider is push point of the prop. Two diff length hulls with same height of push point will perform significantly different. Yes, the shorter hull may have less surface area to drag and less weight, but it may be putting a lot of that forward thrust into the front ball of the boat thus causing a pushover effect and wasting thrust from the prop.... A longer bottom may allow more forward thrust to continue forward rather than being wasted burying the front of the hull down.
A little scientific video below:
Water Walker Props, Inc.
(863) 676-PROP
scottyroll
sidejobs and andrewmcd have excellent points.With that power you should probably roll with the longer hull. Another thing to consider is the variety in hull dimensions, especially fiberglass, they all have different degrees of tapering meaning that the 2 same length hulls wont necessarily have the same amount of surface area on the ground. some are flat and some are more rounded.
:Scotty-Roll:
FLAwless
Hog Guts
Post by Hog Guts »
Well I ended up with the opposite of my original intent, funny how that works. Have an 11-6 should be on the water by this weekend I'll know what it will do once I play with it but I'm fairly sure it isn't going to sit there when I mash the gas :)
dusty burch
Post by dusty burch »
14 by 8 jimmy white is what I would recommend. ... best ride boat aaround
Packman
Post by Packman »
Hog Guts wrote:Well I ended up with the opposite of my original intent, funny how that works. Have an 11-6 should be on the water by this weekend I'll know what it will do once I play with it but I'm fairly sure it isn't going to sit there when I mash the gas :)
I know how u ride Hog , that 11'6 will burn the woods up.
Swamp nugget, Your four banger bud
SJRAA VP
Bruce
Post by Bruce »
Hog Guts wrote:Other than the obvious foot and a half, what changes with the feel / handling of the boat?
Thanks
Are you wanting to get rid of your old set up hull riggin?
12 foot Mamba "The Underdog"
Hog Guts
Post by Hog Guts »
Already did this past weekend. Out with the old in with the new - good day. Rigging came back from Excell Coatings at port Canaveral today they did a beautiful jobImage
Post by kwanjangnihm »
lets see more photos of your build HG!! :thumbleft:
Hog Guts
Post by Hog Guts »
I'll drop some on a new thread
