need to know make of hull and to find a new rake to fit it
fireplum
Post by fireplum »
anyone know what make this hull is, and I want a new rake for the front to fit it with a place for lights- any ideas?
The Bone Collector.......
Re: need to know make of hull and to find a new rake to fit
Post by One Eyed Gator »
Looks like an Alumitec
scottyroll
Post by scottyroll »
That hull looks similar to the one on the government boat in the classifieds, so maybe an airgator :scratch:
And you could probably just modify your existing rake to accommodate the lights.
:Scotty-Roll:
FLAwless
stroked470
Post by stroked470 »
Why not just keep the same rake and bolt a light bar to the top of the rake with a backing plate underneath?
Swamper470
Post by Swamper470 »
or put some lights high on the cage so you can see above the grass
13' 6" Cottonmouth, 0-470-L, Sensenich 72" 3 bld H Series
KRVSA Member
http://www.krvsa.com/
fireplum
Post by fireplum »
this is an older picture- the rake is trashed now, and already have the cage lights. I need something contained in a better quality rake.
no name or serial numbers on the hull anywhere...
terrible ted
Post by terrible ted »
I think any local builder would make you a rake to fit.
dblj006
Post by dblj006 »
Triple W Airboats Phone:(863) 467-6265
http://www.triplewairboats.com/
Broke.
fireplum
Post by fireplum »
serial number I found with info sent on post
AON00693K798
STAMPED ON THE -RIGHT REAR BACK EXTERIOR
IS THIS A DIAMONDBACK? OR OTHER?
alumitech520
Post by alumitech520 »
definitely an alumitech hull and it is also a 1998
fireplum
Post by fireplum »
thanks!!!!
