Alternator
LJohnson
Alternator
Post by LJohnson » Sat Feb 28, 2015 8:41 pm
I've ran a wire from my alternator to my volt gauge, but haven't connected either end yet; I'm not sure which connections to make.
The back of the alternator has two spots for wire connectors to slide onto, and I'm not sure if I need to use the one on the left or the one on the right.
Also, on the bottom of the voltage gauge, there are two small studs with nuts. One of them has a "S" stamped next to it and the other has a "I". Which one do I use?
220GPU, Big-O Hull
LJohnson
Re: Alternator
Post by LJohnson » Sat Feb 28, 2015 8:42 pm
The alternator is a kinda cheap "Driveworks" remanufactured one wire from Advance Auto
220GPU, Big-O Hull
R L Williams
Re: Alternator
Post by R L Williams » Sat Feb 28, 2015 9:13 pm
You only need the big wire hooked to your system, (hot side of solenoid), hook the voltmeter to a ground and the ignition switch accessory post.
The one wire alt will energize when you rev the motor the first time
"GRASS SCOOTER"
Member of the over the hill gang.
United Sportsmen Airboaters Alliance.
NRA life member.
CactusJack
Re: Alternator
Post by CactusJack » Sun Mar 01, 2015 8:45 am
Like RL said, just the big wire is enough to run it, the 'I' is likely to be the indicator light (dash light) which should come on when you turn on the key and go out when it is charging once you start :salute:
Smuggler
Site Supporter - VII
Re: Alternator
Post by Smuggler » Sun Mar 01, 2015 9:02 am
LJohnson wrote: Also, on the bottom of the voltage gauge, there are two small studs with nuts. One of them has a "S" stamped next to it and the other has a "I". Which one do I use?
If it's a voltage gauge it goes like this..
If it's a Amperage gauge it goes like this..
Re: Alternator
Post by SWAMPHUNTER45 » Sun Mar 01, 2015 6:30 pm
When you fire it up it will read the battery until you spin it up to around 1200 rpm and "excite" the regulator.
Southern Style
Re: Alternator
Post by Southern Style » Mon Mar 02, 2015 8:28 pm
Yup... Starting it wont show needle movement.. Rev it up and watch it punch over.... I idled around for a LONG TIME with every light burning... and had a dead battery in a few hours.. Had to learn the hard way.. Not all of them are "Self Exciting".... So, just know whatcha got.. LOL
KRVSA Member
SJRAA Member
KCCO
