Strongest brand of slick bottom
elChupacarburetor
Post by elChupacarburetor »
I've seen several brands of slick bottom around. Seems like Quick Slick, Frog Spit, Owl Sh!t, Goat Eye Juice and N!##er Snot are just a few brands I've seen.
I run a lot of dry ground but just grass and sand. I stay off the rocks, stumps, cypress knees and stuff. I don't want to use poly because it makes a boat drive like a barge.
I just want to know what lasts the longest on the old slick bottom glass boat.
12' Gilileo / Lycoming O-360-A1A / 72" 3-blade Sensenich Saber
gatorfrog2
Re: Strongest brand of slick bottom
Post by gatorfrog2 »
Oh man here we go AGIAN. :happy1: I think a lot has to do w/ how it's applied. Cure time etc. Polyester vs. vinyl ester resins. I know I wore threw GATORGLIDE in 1-2trips to the river. Grass sand etc. Nothing harsh. Switched to SUPERSLICK2000 an I beat the CRAP out of it. Mangrove roots, limestone rocks etc. That's the only thing that scratches it. Grass makes it SLICKER. BUT. I have a stainless steel bottom. I think Fasco has the best stuff that will adhere to stainless. BUT prob gonna give QUICKSLICK a try next time an see how it holds up. :stirpot:
Lycoming 0320H 3/4 alum. Custom deckover 69" Narrow Whispertip w/ SuperSlick2000
jopete
Post by jopete »
i've used the superslick from Fasco. it's pretty good.
fl cracker
Post by fl cracker »
Call Brian at Quickslick 863-581-9710. Give him a shout!
" I have two guns...
One for each of you "
2017 Al David / stroked LS
Gangreen
Post by Gangreen »
Quentin Moore. Who has his recipe?
Bruce
Post by Bruce »
steelflex superslick 2000 from fasco is by far the toughest ive tried gallon for gallon its a lil pricier but you get what you pay for in my opinion
12 foot Mamba "The Underdog"
jeepinocala1111
Post by jeepinocala1111 »
I have quick slick and so far it's great. Everyone I talk to says it's the stuff to have.
BUSHHOG85
Post by BUSHHOG85 »
elChupacarburetor wrote:I've seen several brands of slick bottom around. Seems like Quick Slick, Frog Spit, Owl Sh!t, Goat Eye Juice and N!##er Snot are just a few brands I've seen.
If you run a lot of sand you may as well throw a few hundred bucks down the shitter cuz none of it will last.
SC 480 13x7'6 HAMANT
520 13' RICOCHET
DuckNutt
Post by DuckNutt »
Wearlon made by Wet Lander. I love the stuff and the company is very responsive.
Post by Deano »
BUSHHOG85 wrote:If you run a lot of sand you may as well throw a few hundred bucks down the shitter cuz none of it will last.
Here, I was going to say that sand would be the nemesis of anything you choose, but direct and blunt may better convey the point. :D
In any case, it's the price to be paid to avoid that "barge like" bottom. :lol: :lol:
HAMMERHEAD
Post by HAMMERHEAD »
Epoxy products will always be tougher and bond better. All wil require proper preparation for best bonding. The slickest will be the subject of debate for a long long time, and a lot of the professional advice you will get on this site will vary depending on what area they are from and who they are friends with.
GeeLeDouche
Post by GeeLeDouche »
I have heard really good things about the Wetlanders longevity. I believe it is a basecoat / topcoat process instead of a single application.
I have quickslick on my mudboat and it has started chipping off after less than 3 months of occasional use (mostly running ice), but IMO it is by far the slickest stuff out there so its a trade off. And its easy to fix the places it chipped off, just rescuff/grind, clean and reapply.
Bottom line, its all in the prep.
coopb6
Post by coopb6 »
Fasco steel flex super slick 2000. Lasted a year on my boat and is slick as hell.
elChupacarburetor
I'm going to try the Fasco Steel Flex. We'll see if it lasts longer than the Columbian Black Market Yak Piss I had on there before.
John.obryan
Post by John.obryan »
Elchupacarburator, how'd the steelflex hold up? Just bought a Gilileo 12' av 0540 with old frog spit that needs to be redone...wondering which product to go with?
jeepinocala1111
GeeLeDouche wrote:I have heard really good things about the Wetlanders longevity. I believe it is a basecoat / topcoat process instead of a single application.
If your quickslick is chipping off either you put it on aluminum or the wrong way I had quickslick on my last boat done by Jimmy White you couldn't get that stuff off if you wanted to. It never cracked even after dry loading the boat many times to pavement.
HAMMERHEAD
Anything epoxy based will be stronger and stick better! Period. Prep is important with any of them!
CypressHunter
Post by CypressHunter »
I've tried frog spit, quick slick, and ended up going back to Steel flex 2000.
Frog spit was pretty good, quick slick didn't hold up well at all mostly because I got the wrong info and was told I could put it on over frog spit. I ground it all off and went to steel flex and it has held up very well.
