Slip-plate-graphite-dry-film-lubricant
SteveReid
Site Supporter - VII
Post by SteveReid » Thu May 07, 2015 7:38 am
http://www.zoro.com/slip-plate-graphite ... aign=First This popped up as a popup ad and i'm just passing it on. I never heard or seen it before, so I'm just sharing. Just looks interesting.
Shippee123
Re: Slip-plate-graphite-dry-film-lubricant
Post by Shippee123 » Thu May 07, 2015 8:47 am
Yes this is used on Car Haulers where you have metal to metal contact for the moveable rails, brush it on and it lasts for a few months depending on wear. Nasty Sh!!t to get off you when it dries.
radtech
Post by radtech » Thu May 07, 2015 9:16 am
Definitely looks interesting. Graphite is super slick. I'd be interested to know if anyone has or was willing to try it. Hell, I might even try it seeing as it's only $65 a gal
Shippee123
Post by Shippee123 » Thu May 07, 2015 9:44 am
I can tell you if you step on where it is on metal and you aint careful you will be laying on the ground.
radtech
Post by radtech » Thu May 07, 2015 10:06 am
Think I'll contact the seller and see if it will bond to poly. Worth a shot. Might be the new poly revitalizing secret. lol
Post by John Fenner » Thu May 07, 2015 12:42 pm
I posted this in the poly butter post , use it on motor grader blade guides and turntables
Post by John Fenner » Thu May 07, 2015 12:43 pm
It should stick to poly fine.
radtech
Post by radtech » Thu May 07, 2015 4:24 pm
Wonder how long it would last in water. That would likely be the problem area. But if it's heck to get off your skin once it dries, it might just work after all
Post by Deano » Thu May 07, 2015 5:05 pm
Dang, Radtech you're acting like you got a 305 DD. :shock:
Maybe it will stick to the grass better than to poly.
Better bump up your hazardous waste clean up coverage, before you go leaving the lone trail of that stuff all over the place. When you're the only one with that residue on your hull, the entire clean up bill will be yours. :stirpot:
radtech
Post by radtech » Thu May 07, 2015 8:34 pm
Lol I hear ya Deano. Definitely gonna get more info first, but if I can get by a lil longer without replacing my poly, it would be nice
radtech
Post by radtech » Thu May 07, 2015 8:36 pm
