Fuel pump stopping - enough already
Hog Guts
Post by Hog Guts » Mon May 25, 2015 5:27 pm
Alright... On my second fuel pump after first one stopped. Then new one stopped and I was way out there. Decided to take it apart that time. Pulled parts out out back together then it worked. I put original fuel pump back in boat because at that point figured I could fix it too if needed. On way out today motor cuts off no fuel and fuel pump quiet again. Seriously?? So I take the original one apart and it full of black crap which I have a photo of and I had my gopro today so have a good video of it being taken apart as well. But I want to know what this cramp that keeps blocking the screen and stopping the fuel pump from working. New tank, new hoses, new pumps etc have no idea where all this crap is coming from. Hamant built the tank I wouldn't think it came with all this stuff inside new but that's about my only guess right now since there is shiny aluminum slivers in there mixed in with the black stuff. Ran magnet over it and it's not sticking.
Any clues?
nomad41
Re: Fuel pump stopping - enough already
Post by nomad41 » Mon May 25, 2015 5:30 pm
Looks like the insides from your fuel hose. Depending on the type of fuel hose your using this great gas we buy eats it up. You should be using only type A USCG approved fuel hose. Cost a little more but it is better.
Treasurer FAA
Svcliche@yahoo.com
Scarecrow
Post by Scarecrow » Mon May 25, 2015 5:34 pm
My thoughts exactly. :thumbleft: :rebel:
scottyroll
Post by scottyroll » Mon May 25, 2015 5:52 pm
I agree on the fuel hose diagnoses. However, I don't think the swastika pattern fuel pump design is ideal either :lol:
:Scotty-Roll:
FLAwless
Hog Guts
Post by Hog Guts » Mon May 25, 2015 5:57 pm
So avgas eats regular fuel hose up? Who woulda thunk.... That's why I ask you smart fellas :). I'm going to take a photo of my hose now because if that crap is upstream then it's downstream too. Ack!
That's not even funny. It says not for fuel injection system right on the fuel hose (I never actually read it) I can only assume that if it matters what I use it for then.... Dammit man. Well I hope that's it I'll replace it all and my problem gone forever. Image
Rich Andrews
Post by Rich Andrews » Mon May 25, 2015 6:00 pm
try some PTFE hose,not cheap but engineered for fuel.
LOHA is AHOL backwards
Post by SWAMPHUNTER45 » Mon May 25, 2015 6:03 pm
That hose actually reads "Fuel Vapor" hummmmm?
Hog Guts
Post by Hog Guts » Mon May 25, 2015 6:04 pm
I'll buy gold plated if I have to this has to be the cheapest part of the whole boat and it's the only thing I've had problems with I still can't believe fuel hose just doesn't work cause it's cheap. They shouldn't even sell it. Where can I get the best type I need about 8 feet. -- shaking head
Rich Andrews
Post by Rich Andrews » Mon May 25, 2015 6:08 pm
u could also have an oxygen problem entering your system causing the line to deteriorate.
Post by SWAMPHUNTER45 » Mon May 25, 2015 6:10 pm
Dude try a local marine supply and see what they have if not check Summit or Jegs.
pontoon outlaw
Post by pontoon outlaw » Mon May 25, 2015 6:12 pm
hog I got mine from sonny's in Melbourne, been on the boat 3 years now no problems knock on wood, but I have a filter in front of the pump and after the pump to keep this crap ethonal gas cleaner!!!!!
mojoe
Post by mojoe » Mon May 25, 2015 6:35 pm
You go to the parts store and ask for 8' of fuel hose. You would expect 8' of fuel hose.... Not fuel vapor hose that is not for use in fuel injected systems.
Mark 7:9
Skeeter-Gee
Post by Skeeter-Gee » Mon May 25, 2015 7:15 pm
Def fuel line breaking down we see it in vst's of outboards all time (vst is where the electric fuel pump is on fuel injected engines). Below deck fuel line (type a) will work well its double walled and can handle the uv as well. Its fairly cheap per foot we sell it i think for under 3 bucks a foot . On a side note at least the av gas helps with lubing the pump up . Fuel today is shit and it does not limit itself to ethanol we see the same issues with non ethanol fuels .
Scarecrow
Post by Scarecrow » Mon May 25, 2015 7:22 pm
Cut that gas hose in half and see what the inside looks like. :thumbleft: :rebel:
dblj006
Post by dblj006 » Mon May 25, 2015 8:23 pm
That is PCV breather hose. Replace it.
Broke.
terrible ted
Post by terrible ted » Mon May 25, 2015 8:24 pm
I went to a marine store and bought ethanol approved hose its blue in color
trailerdon
Post by trailerdon » Tue May 26, 2015 7:06 am
10/4 on that fuel hose. Next purchase needs to be a racor filter before fuel pump, they are rather pricey but well worth it. Not only will a good filter remove any of the solids that come through, but also has a clear bowl on the bottom so you can visually see if solids or water are present. I have been running that set up for 3+ years with a Fausett fuel pump and have never missed a beat.
diamondback0320
Post by diamondback0320 » Tue May 26, 2015 9:05 am
X2 on the blue marine fuel line I've used it on 3 boats now with no issues,I bought some regular black fuel line for my 1st boat & that junk lasted bout 2mnths if that,boathouse on us1 or carp down here in grant carries it for bout 1.80ft
mdelaney
Post by mdelaney » Tue May 26, 2015 10:11 am
I've had the blue hose fail on 2 boats in the last year. It has a plastic lining in it that the ethanol eats through! The stuff was only on the boats for about 2 years!
Hog Guts
Post by Hog Guts » Tue May 26, 2015 4:00 pm
I use avgas and want the best hose everyone agrees on. Oh never mind nobody ever agrees
Post by SWAMPHUNTER45 » Tue May 26, 2015 5:00 pm
I think this is a big issue and we have just scratched the surface!
How many guys on here have had pumps go out in the past year prematurely?
I had a very reliable Carter "bouncing" pressure and swapped out but I am paranoid about pressure because I love the Happy Gas!
There is some bad rubber hose out there and HogGuts was then dude who sounded the alarm.
We need someone to ID the best hose for pump gas, Sunoco110 and AvGas. This black stuffisSHIzT
Southern Style
Post by Southern Style » Tue May 26, 2015 6:34 pm
Glad to see they found the issue... Sometimes that "GUY" behind the counter doesn't quite know exactly what you need it for, OR he just gave you something that had the word "FUEL" on it.. Change them hoses !! You should be just fine... I had my fuel pump stop 3 times in 45 minutes right when I built it.. When I went and wiggled the ground wire, it fired up again.. I have heard it so many times on here, if electrical, 98% of the time, its the ground!! LOL... Yours is the other 2%.....
Glad you got her figured out..
KRVSA Member
SJRAA Member
KCCO
Skeeter-Gee
Post by Skeeter-Gee » Tue May 26, 2015 7:29 pm
That blue fuel line was sposed to be the save all with liners collapsing etc .Its only a matter of time, right now its hard to find decent fuel line that isnt below deck even the new above deck stuff is showing signs of breaking down . 20 years in the marine industry as a mechanic ,the last 5-6 years have rewritten everything we knew about fuel lines degrading . Those of you running the blue stuff ,simple way to check is to squeeze the fuel line, if its pretty uniform and firm usually good. When the inner liner collapses it will be pretty squishy .In other words you would be able to pinch it in your fingers fairly easy . Stay away from the sierra grey fuel line , attwood fuel line assemblies that are grey , the get hard as a rock and brittle after some time in the sunlight.
Adam ,
diamondback0320
Post by diamondback0320 » Tue May 26, 2015 7:34 pm
Yep had same problem with my fuel pump shuttin down outta nowhere & bought a new 1,come to find out it was the switch in the panel had some corrosion on it,as far as the hose they say with that blue marpac ethanol resistant hose you should cut the end off bout an inch each time its removed & lube the barb when putting back on so not to damamage the liner & they claim that any non-ethanol fuel will not break it down
Daniel Altman
Post by Daniel Altman » Tue May 26, 2015 7:51 pm
I have a draw straw that picks up 1" from the bottom. Fuel pump pulls fuel through a small inline filter and then pushes to a fuel filter/water separator. Then on to the carb. I change out all fuel hoses every year though. I'm particular like that.
10' Thurman copy, O-320, WW Cypress, BRAB 51 & RRAA 15
"You can't tourniquet the taint!" Archer
