lenco trim tab wiring question ??
airjohn81
Post by airjohn81 » Sat Jun 27, 2015 3:05 pm
have a lenco trim tab and my console already has a switch for the tab... question is how do i wire up my tab to the switch.... do i need a relay?? any help is appreciated
:old_glory: :florida: :rebel: :rebel: :rebel: :rebel: :rebel: :rebel: :rebel: :rebel: :rebel: :rebel: :rebel: :rebel: :rebel: :rebel: :rebel: :rebel: :rebel:
BluByU2
Re: lenco trim tab wiring question ??
Post by BluByU2 » Sat Jun 27, 2015 3:20 pm
I just wired mine directly to the battery. You could use a fuse, or breaker, or relay if you choose, but I took the simple route.
flcracker9
Post by flcracker9 » Sat Jun 27, 2015 4:18 pm
You can purchase the Lenco wiring harness. It comes with Deutsch connectors, just plug them in, run 1 lead to the battery (best to run it fused), 1 lead to a ground, and your in business
Smuggler
Site Supporter - VII
Post by Smuggler » Sat Jun 27, 2015 5:16 pm
Here you go...
airjohn81
Post by airjohn81 » Mon Jun 29, 2015 9:35 am
thanks guys an especially smuggler ... exactly what i needed!!! as always thankyou guys for all the great knowledge an great people on here !!! slide safe friends
Andrw7264
Post by Andrw7264 » Tue Jun 30, 2015 1:37 pm
I know he already found out what he needed for his application, but here is a diagram that helped me when wiring a momentary switch with relays. Hopefully this might help someone in the future.
midnight rider
Post by midnight rider » Tue Jun 30, 2015 4:49 pm
The first picture is also applicable for bypassing the reversing relays on a power pole. I say this cause I'm noticing more on airboats
