CH-4 Belt
doenute
CH-4 Belt
Post by doenute »
What would you do?
On one set of upper assembly holes the belt whines...index it back only one set of holes and the tips of the prop have about 1/2" wiggle before the engine compression stops them.
Which would you go with??
Thanks
Bill
Ol Yeller
Re: CH-4 Belt
Post by Ol Yeller »
Looser without a doubt. When the belt wines it's too tight. Hard on the bearings.
rjfjr
Re: CH-4 Belt
Post by rjfjr »
I agree looser run for a few hours maybe 20-30 then try adjusting it again if still whines run it looser
doenute
Re: CH-4 Belt
Post by doenute »
Thanks. Definitely sounds better looser. It has 70 hours on it like this--any ideas when it might stretch out a bit as it implies in the CH-4 Instruction manual? They seem to indicate a belt only needs to be tightened once or so in its life.
Bill
Bruce
Re: CH-4 Belt
Post by Bruce »
Belt drives whine... When you start it loose does it clunk at an idle and once it warms up is the slack gone?
12 foot Mamba "The Underdog"
doenute
Re: CH-4 Belt
Post by doenute »
When loose it actually sounds and feels pretty good. Just never had the situation on my old CH-3 where I could move the prop tips because of slack in the belt like this one. That got me nervous enough to ask here.
Thanks
Bruce
Re: CH-4 Belt
Post by Bruce »
doenute wrote:When loose it actually sounds and feels pretty good. Just never had the situation on my old CH-3 where I could move the prop tips because of slack in the belt like this one. That got me nervous enough to ask here.
Thanks
every ch4 ive heard has seemed much louder than my ch3 wider belt i guess i dunno if its warm and it still has slack its too loose
doenute
Re: CH-4 Belt
Post by doenute »
I could not believe how stiff the CH-4 belt was when I put it in.
