Superslide Poly
Huntingwithahoyt
Superslide Poly
Post by Huntingwithahoyt »
Anybody running super slide poly from Horn Plastics? Searched past posts and was just looking for any new comments on anyone using it? I run the gulf fishing in the flats and am curious if will hold up any better than other poly on the occasional accidental rock/oyster mishap.....
scottyroll
Re: Superslide Poly
Post by scottyroll »
I think they all must be pretty much the same when your talking about a specific type of polymer makeup like UHMW (whatever the acronym is) and there might be just slight differences regarding aspects such as silicon content, which wont protect you any better.
It really must come down to the thickness and how well it is mated to the bottom of the boat.
Regardless, a significant oyster bar or rock encounter will damage at will any practical means of bottom protection.
:Scotty-Roll:
FLAwless
GeeLeDouche
Re: Superslide Poly
Post by GeeLeDouche »
I have used Mike Horn with Polymer Systems. He's a good guy and offers a good product.
http://polymersystemsllc.com/airboat-polymer/
Andrw7264
Re: Superslide Poly
Post by Andrw7264 »
I ordered blue iron directly from super-slide/Horn plastics and ran it for years with no complaints. Found it to be cheaper to order it directly from the company and have it shipped to my door. The blue iron was tough and held up great.
John C
Re: Superslide Poly
Post by John C »
I have run the blue iron poly for about 5 years. I have also run the black and the white. I like the blue iron better. Superslide also offers the red hot superslide which has glass impregnated in it. I have not run it yet, but it is supposed to be more abrasion resisant than the blue iron. They also offer the yellow quartz superslide. This product has Quartz impregnated in the poly and makes it more abrasion resistant than the blue and the red. They all have silicone added and are very slick. It is a very good product.
never2fast
Re: Superslide Poly
Post by never2fast »
UHMW (ultra high molecular weight) (blue iron). I like the blue iron lot better than any of the other stuff. it holds up to the road, gravel, rocks, dry ground etc a lot better than any other stuff I have used. much more harder and durable. this blue iron has lasted me longer than any other polymer. It has 2% silicone added and is UV stabilized, the silicone reduces wear, and decreases frictional heat. I buy a roll of 60 feet at a time. so let me know if you ever need some.
I'm located Okeechobee. Jason 863-634-4184
rjfjr
Re: Superslide Poly
Post by rjfjr »
Jason how much for 8x13 thanks. I'll come get it when I'm ready so don't worry about shippin
Rich
never2fast
Re: Superslide Poly
i will have to call and get a quote. my roll is 6 feet wide. but in the past when I have had a special order that size it was around $800-$900, and it would be shipped in about 2-4 weeks. for a 6x13 I have in stock it would be $715
Huntingwithahoyt
Re: Superslide Poly
Thanks guys for the replies....I have talked to them on the phone and they now make the blue iron in black....my size would be 8x13 too....Jason I'm curious to see what the price is?
Polyguy
Re: Superslide Poly
Post by Polyguy »
Hey guys, UHMW is a polyethylene as you all know, the silicone does help significantly, keep in touch if anyone needs some.
mcm4
Site Supporter - VII
Re: Superslide Poly
Post by mcm4 »
Mike Horn is a really good guy to work with, best customer service ever, great product, best prices...
CONTINENTAL CRACKER
Re: Superslide Poly
Post by CONTINENTAL CRACKER »
scottyroll wrote:I think they all must be pretty much the same when your talking about a specific type of polymer makeup like UHMW (whatever the acronym is) and there might be just slight differences regarding aspects such as silicon content, which wont protect you any better.
I will have to disagree on the damage part of this post. I have ripped many sheets of poly. I put the blue iron on my last boat. A friend barrowed my boat and he hit a Toyota straight axle front end in the marsh. It hit at the front right of the hull to the back left. It did rip but it only got a 2 inch tear in it. That is the toughest poly I have seen. It was the knuckle bolt sticking up that went across the bottom. He was running the boat hard,and for it to only rip that small of a area is some tuff poly.
I WOULD RATHER PADDLE A CANOE THAN OWN A WATERPUMPER
