Ballistics gearbox question
mormon
Postby mormon » Wed Jul 29, 2015 10:40 pm
I have a 2.7 ballistics gearbox i just put on my boat. Its bran new. When i start it up without the prop on it idles smooth and when i put the prop on it vibrates bad that the airfilter spins around. Is there something i can do to make it quit vibrating so bad
LS3 13'6 HULL 2.7 GEARBOX 3 BLD R
dodobird
Re: Ballistics gearbox question
Postby dodobird » Wed Jul 29, 2015 11:32 pm
well if u know ur prop is balanced and true th :florida: en id clock the prop keep moving the prop 1 hole bk n see if that takes it out
13' laser 360sbc oxdrive 2.68 .... 80" 3 blade whispertip ex :florida:
mormon
Postby mormon » Thu Jul 30, 2015 6:47 am
Its a sensenich 3 bld R its new never used. Each bld is pitched the same
budman6023
Postby budman6023 » Thu Jul 30, 2015 7:41 am
should have a good rubber motor
mount and should have a good flywheel like a jw
DynaMarine
Postby DynaMarine » Thu Jul 30, 2015 7:43 am
How are you pitching your prop? Eyeballing it using pitch reference stickers on the blade? Digital angle finder? Warp drive protractor? Tracking the trailing edge at a given point? Lots of things to consider even outside of prop pitch that can cause vibration...adding a prop just amplifies it
Shane Lavalette
President/Owner
DynaMarine Performance Boats
785.218.9449
www.dyna-marine.com
shane@dyna-marine.com
mormon
Postby mormon » Thu Jul 30, 2015 7:53 am
By the stickers on the blade
scottyroll
Postby scottyroll » Thu Jul 30, 2015 7:55 am
mormon wrote:By the stickers on the blade
There lies the problem...
:Scotty-Roll:
FLAwless
mormon
Postby mormon » Thu Jul 30, 2015 8:01 am
It shouldnt be like that at an idle i can see at a high rpm but when it goes over 1000 rpm it clears up so it aint the prop
LoxStroker383
Postby LoxStroker383 » Thu Jul 30, 2015 8:04 am
I get little vibration on mine too. What is the best way to check the pitch angle on the prop? I have a cheap husky digital level from Home Depot. Is there a better way?
14x8 Diamondback, 383 Stroker, 2.38 OxBox, 80" 3 Blade NGR
DynaMarine
Postby DynaMarine » Thu Jul 30, 2015 8:46 am
mormon wrote:It shouldnt be like that at an idle i can see at a high rpm but when it goes over 1000 rpm it clears up so it aint the prop
What's your idle RPM?
Shane Lavalette
President/Owner
785.218.9449
www.dyna-marine.com
mormon
Postby mormon » Thu Jul 30, 2015 8:50 am
800
HuntingBigun
Postby HuntingBigun » Thu Jul 30, 2015 11:02 am
agree just like Blackwater says on the R use both digital angle and tracking pointer, call Sensenich and talk to Darrin he will walk you thru it, I set with digital angle first and then check with tracking pointer
Bigun
http://www.krvsa.com
http://krvsa.com/product/airboat-raffle-tickets/
mormon
Postby mormon » Thu Jul 30, 2015 11:04 am
Thanks ill try it at lunch time thanks for everything
GeeLeDouche
Postby GeeLeDouche » Thu Jul 30, 2015 11:34 am
curiously,, Where are you located?
1648"M (& floatation pods) "Lowe" modified V Jon boat with a 31hp mudbuddy hyperdrive.
mormon
Postby mormon » Thu Jul 30, 2015 11:35 am
St.cloud
nomad41
Postby nomad41 » Thu Jul 30, 2015 5:03 pm
Treasurer FAA
Svcliche@yahoo.com
barhopper
Postby barhopper » Fri Jul 31, 2015 6:35 am
Be sure to have the serial numbers on the blades. I was once sent a non matching blade. When I talked to the manufacturer they knew immediately what was wrong by the serial numbers.
GeeLeDouche
Postby GeeLeDouche » Fri Jul 31, 2015 12:07 pm
Thanks for sharing Nomad. that's a very good article!
jopete
Postby jopete » Sun Aug 02, 2015 10:57 pm
if you have a iphone or any type of smart phone you can get a free app for a digital level. just slap your phone against the prop.
has worked for me several times.
unless i get man and smash it, i always have my phone on me. lol
Comanche-pup
Postby Comanche-pup » Sun Aug 02, 2015 11:04 pm
Iphone has one built it without buying App on second page of compassImage
I have checked it with a high dollar digital angle finder and it was dead on
Users browsing this forum: JCGator and 19 guests
