No prop on gearbox
SthrnStyle3
No prop on gearbox
Postby SthrnStyle3 » Thu Aug 20, 2015 1:33 pm
I'm just wanting to check with yall before I potentially make a mistake or not. My motor has been rebuilt and hasn't even been started yet. So I need to start it up to follow break-in procedure but I need to know if it's ok to run a motor and gearbox with out the prop on the gearbox..?
scottyroll
Re: No prop on gearbox
Postby scottyroll » Thu Aug 20, 2015 2:36 pm
Prop isn't necessary but def gearbox IMO
I used a shop fan next to the radiator for my flat tappet break in.
I've also heard of using a water hose to spray the radiator down as well.
Make sure and prime the oil pump, use zinc, and put oil in the filter 8)
:Scotty-Roll:
FLAwless
SthrnStyle3
Postby SthrnStyle3 » Thu Aug 20, 2015 6:07 pm
Thanks for the advise guys. I forgot about no airflow over the radiator... I have a prop but the cage isn't done yet and I'm not sure if I want to run the prop without a cage. Lol
rbjscott
Postby rbjscott » Fri Aug 21, 2015 12:23 am
Running the gearbox with out a load is good for the box. burnishes the gears. Industrial folks pay the gear mfg. to run the gears in.
"The price of Freedom is high! And the sound of Freedom is loud!" (Jet fighter pilot)
John C
Postby John C » Fri Aug 21, 2015 9:43 am
A constant spray of water on the radiator will keep it cool while running the motor. It actually works better than a fan and will keep it a little cooler.
