Webbing
krazymatt
Webbing
Post by krazymatt »
I want to redo the webbing on the inside of my boat. It's a 12' JB. How much does it usually take to do 1 boat. I know I need to get the webbing solution and mix it with lacquer paint, I'd like to lay it down pretty thick/cover a lot. What do I need to do to prep my hull before I spray it?
harsensmarshrat
Re: Webbing
Post by harsensmarshrat »
When I had to re-apply mine I wanted to apply a heavy amount as well. I used about 2-2.5 quarts of the stuff...
Marsh Magic Marine
Re: Webbing
Post by Marsh Magic Marine »
When using webbing solution mixed with gelcoat and shooting with a gelcoat gun , all you need is about 1/3 of a quart cup to apply a pretty heavy coat of webbing on a 12" to 13" hull.
Ronaldregan
Re: Webbing
Post by Ronaldregan »
Did back of cabin ti fantail ,2eng. Boxes , 3 ice boxes that hold 45 boxes of shrimp on 36/14 shrimp boat. Used 1 qt. u can mix webbing solution with lacquer it goes a long way
woods and water
Re: Webbing
Post by woods and water »
Heavy webbing in a 12ft will take about 1 qt
krazymatt
Re: Webbing
Post by krazymatt »
I got 1 quart of webbing solution and 1 quart of lacquer paint. How much of each do I use 1:1?
Ronaldregan
Re: Webbing
Used 8oz. Lacquer to 1 qt. solution. If u keep solution in frig.it will Webb heavier
krazymatt
Re: Webbing
Post by krazymatt »
What kind of spray gun do you guys use to spray it?
Gary S
Re: Webbing
Post by Gary S »
Just go to Harbor freight and buy a cheap gun used to spray automotive paint. You can get a pretty purple one for less than $40.00. I would recommend a gravity feed one
Ronaldregan
Re: Webbing
X2 that is the gun I used, adjust gun and air pressure, try on paper the more distance between gun and boat the heavier it will spray
444kyle
Re: Webbing
Post by 444kyle »
Ronaldregan wrote:Used 8oz. Lacquer to 1 qt. solution. If u keep solution in frig.it will Webb heavier
ok I know this is a old. but i just tried some test shoots and my webbing is coming out real this and very light to where it is floating all over. i mixed to what the bottle said which is 2 parts oaint i part solution. thats way off what you are saying to mix at. Im sure thats where my issue is but just wanted some opinions.
14ft JB Hull,Lycoming GSO480,10 blade warp drive
Gary S
Re: Webbing
Post by Gary S »
Try less air pressure.
happy harold
Re: Webbing
Post by happy harold »
try using an undercoat gun.
