Required HP?
Planeguy
Required HP?
Post by Planeguy » Tue Sep 15, 2015 7:17 pm
Is there a "rule of thumb" way to determine how much HP and/or thrust a boat should have? I understand about the difference changing pitch on a prop can make.
Thanks,
Jeff
scottyroll
Re: Required HP?
Post by scottyroll » Tue Sep 15, 2015 7:34 pm
A lot of things to factor in but my unscientific pull a number out of my A$$ answer would be one horse for every 4 lbs. of boat weight to run dry. It has worked for me each time so far on a geared carmotor setup.
:Scotty-Roll:
FLAwless
mojoe
Re: Required HP?
Post by mojoe » Tue Sep 15, 2015 8:19 pm
X2 on 1/4hp/lb
I have estimated my aluminum 0-540 at .29hp/lb and it will run most dry at 2100-2200rpm. Moist grass at 1700 and it will run for miles bone dry without ever flooring it. And even if I do, I have a pedal stop that keeps it from ever really being floored.
If I load it down (700 lb) and approach .19hp/lb it will still run dry well, but I find myself having to get on it when it's sticky or up hill.
If you can target .25hp/lb loaded it will really run impressively!
Mark 7:9
Hardtail
Re: Required HP?
Post by Hardtail » Tue Sep 15, 2015 8:19 pm
200 hp can easily push 1200 pounds on dry ground which would be 6 pounds per HP with steel flex, I'm not sure about if it were on poly.
Bdriller
Re: Required HP?
Post by Bdriller » Tue Sep 15, 2015 8:29 pm
scottyroll wrote:A lot of things to factor in but my unscientific pull a number out of my A$$ answer would be one horse for every 4 lbs. of boat weight to run dry. It has worked for me each time so far on a geared carmotor setup.
would that be .25 per pound?
mojoe
Re: Required HP?
Post by mojoe » Tue Sep 15, 2015 8:41 pm
:cheers:
Mark 7:9
Tony480
Re: Required HP?
Post by Tony480 » Tue Sep 15, 2015 9:02 pm
As much as you can afford
terrible ted
Re: Required HP?
Post by terrible ted » Tue Sep 15, 2015 9:20 pm
Tony480 wrote:As much as you can afford
don't listen to this man its more than you can afford
dshaw94
Re: Required HP?
Post by dshaw94 » Wed Sep 16, 2015 9:55 am
mojoe wrote:X2 on 1/4hp/lb
So you've got a 540 boat that ways 1034lbs????? I'd say it should run dry like a boss!!
We all got it coming, kid. (William Money)
