Gauge package suggestions
Dirtman
Post by Dirtman »
After a long drawn out process I'm about to start my part of my new boat build. I know the basic gauges will be in the gauge package( tach, oil pressure and temp plus voltmeter ) just curious as to what others thought should be included to keep up with all functions of the engine. It will be a GSO-540. thought about including a boost gauge and an air fuel ratio but don't know if these are really ness. I appreciate any input you guys can give
getitdone
Re: Gauge package suggestions
Post by getitdone »
Fuel Guage and CHT Gauge
"Poachers Dream"
13'x7'6" Hamant Ultralight With 0540 And 72"Q
Dirtman
Post by Dirtman »
I was thinking about CHT as well, unfortunately fuel tank wasn't built with provisions for a gauge but does have a sight tube
farmboy
Post by farmboy »
I'm running a Tach,oil psi,oil temp,volt and a boost/vac gauge. I think that covers ya in my opinion... As far as CHT I would just get a lazer heat gun and check with that. And the AF guage I would use it to tune your carb or injection then I would take it off. I don't think that's something that you would need to leave on it. We tuned mine with a AF meter and then took it off and CHT has never been a issue. Now if i was gonna run dry for long periods of time that might be a different story with running a CHT gauge. Just my opinion...
Olf Art
Post by Olf Art »
This is a subject I enjoy because I like things simple. A lesson can be taken from the motorcycle industry ...... think about how many gauges you normally see on a bike. Usually a tach, a speedometer, and some 'idiot lights', right?
An airboat wouldn't have to be wired much different. We wouldn't need the speedometer, so now you're down to a tach, and if you want, an oil pressure gauge. I'd want the oil pressure gauge just because it would give me some real readings at idle and such, but even that one wouldn't be absolutely necessary. I trust the electric ones.
Think about what you do on a bike to check the gas. You take the cap off and look. A sight glass on the side of a tank takes care of that. You don't even need a keyed starter switch ...... just a locking Perko switch on the batteries that's wired as a 'master switch' and a starter button on the panel, along with some marine grade fuel pump and ignition toggle switches, and a couple extras for lights and such. A DC wiring project is always better when it's kept simple because probably at least 90% of all DC circuit problems come from faulty grounds. My boats only had positive leads running to an appliance. Those were grounded right where they sat. I've done it that way on several things and it worked great every time.
Just food for thought. :)
Dirtman
Post by Dirtman »
I understand what you are saying Olf art. Was either going to ground everything to good solid grounds near the device to be powered or to an actual lug directly from battery ground
