advantages of a 14ft step over 12ft?
Neversatisfied
Post by Neversatisfied »
What is the advantage of a 14ft over 12ft? Using an LS setup. 400CI max. Is it weight? torque roll? or just advancement in technology?
Would a 12ft be sufficent?
All opinions welcome.
Gary S
Re: advantages of a 14ft step over 12ft?
Post by Gary S »
The question is like asking which truck do I want? A chevy Luv or a Silverado. It depends what your going to do with it.
slidingforhogs
Post by slidingforhogs »
From what I've seen on them is this, there isn't really any difference between the 12ft or the 14 ft except length. They both have the same width, etc.. only difference is that u can put a car barge engine on the 14fter.vs aircraft on the 12ft. Except probably a v6 then at the most. But over all the same. With a lil in weight differnce..
11'7 gore ,
220 gpu swinging a woody...
Stomp on it!!!!
Neversatisfied
Not really looking to be competitive in racing but something fun to ride. Nothing super low sided either. Single seater maybe a foot stand rider here or there.
slidingforhogs
What engine setup are u wanting to run?
11'7 gore ,
Stomp on it!!!!
Waterthunder
Post by Waterthunder »
Single seat lightweight race boat style of boat with a 400 cui motor a 12ft is fine.
THE PROOF IS IN THE PROP!
http://waterthunder.com/
321-508-5316
Neversatisfied
~400ci LS with ballistic race box
Waterthunder
There ya go now you have a nice raceboat. I wouldn't bother with a 14ft unless you have one of those 600inch all aluminum motors everyone is starting to run.
321-508-5316
midnight rider
Post by midnight rider »
The only 14' ive seen in person has a supercharged geared AC on it. It has full stainless metal work. side by side seating with seating up front also. And it still would walk away from the two 12' steps we were running with him. One had a 470 and the other a 540 both carb. The two 12' are true 70-80 mph ride boats. The biggest advantage I see with the 14' is it seems to be very forgiving with weight and setup. now I will say that the 14' is actually 13-6" overall. Not 14'.
flshooter
Post by flshooter »
The 14 pops up quicker than 12 footer,feels more free,more forgiving
IO-520 72"Q series on a hawk step
