Stuck lifter or short pushrod?
Strangiato
Post by Strangiato »
220 gpu. New to me. Noise was driving me nuts so pulled valve cover and intake tube on suspect cylinder. I discovered a 1/8 gap between rocker arm and valve/pushrod. Valve is closing fully and seat looks good. Pushrod is not bent. Could this be a lifter not pumping up completely or just a short pushrod or do I need to just tear into it some more and look? Thx
Outlawaircraftengines
Re: Stuck lifter or short pushrod?
Post by Outlawaircraftengines »
Could be a stuck lifter, I have them and also the adjustable pushrods to fix your problem.
Gary Barber
Outlaw Aircraft Engines
www.outlawaircraftengines.com
863-698-0383
Would a worn lobe also give that look?
could be, but rare to wipe a cam on a gpu
Gary Barber
863-698-0383
