Gator hunting small boat adding floatation foam in hull?
jeepinocala1111
Post by jeepinocala1111 » Sun Jun 19, 2016 9:23 pm
I will be gator hunting with my 13ft airboat and was wondering if anyone has added marine foam to the storage area in the nose of the hull? I am worried about the front of the boat with a few guys working up there it gets pretty low. Last year we had a fat buddy up front I couldn't plane up it would have gone down.
Chaseh
Re: Gator hunting small boat adding floatation foam in hull?
Post by Chaseh » Sun Jun 19, 2016 9:30 pm
It won't prevent your boat from sinking, it will however aid in recovery
jeepinocala1111
Post by jeepinocala1111 » Sun Jun 19, 2016 9:43 pm
Chaseh wrote:It won't prevent your boat from sinking, it will however aid in recovery
Will it help with floatation?
southern safaris
Post by southern safaris » Sun Jun 19, 2016 10:17 pm
Old engine builders used to say "there's no replacement for displacement"
Kind works the same for hulls I think the foam would help for flotation if sunk or swamped but the footprint of your boat is what will be displacing water not what is in the boat .... Imho but I'm no physicist or whatever those smart fellas are called
Anthony Hughes
Madison FL
850-973-2642
580-228-5782 cell
Aluminum round-sided hulls
Post by SWAMPHUNTER45 » Sun Jun 19, 2016 10:27 pm
Adding closed cell foam will only add weight.
It only becomes a buoyancy gain after hull is swamped.
Scarecrow
Post by Scarecrow » Sun Jun 19, 2016 10:34 pm
If you float a piece of wood in the water and then put a piece of Styrofoam on top of the wood, does it make the wood float any higher? :banghead: :rebel:
dshaw94
Post by dshaw94 » Mon Jun 20, 2016 2:30 am
What you need to do is tie 5 or 6 helium balloons to your bow hook. That should give you the added front end buoyancy you're looking for. Wouldn't hurt to couple that with a hole bunch of closed cell floatation foam. I'm talking like 1000 pounds worth. Then that rig of yours will float like a cork! :violent1:
We all got it coming, kid. (William Money)
jeepinocala1111
Post by jeepinocala1111 » Mon Jun 20, 2016 5:51 am
Ok well the foam idea is gone. I am going to just be careful this season but by next I will have a larger boat.
Post by kwanjangnihm » Mon Jun 20, 2016 6:40 am
jeepinocala1111 wrote: Last year we had a fat buddy up front
:lol: leave bign at the house!! :stirpot:
Gary S
Post by Gary S » Mon Jun 20, 2016 6:49 am
Get your buddy a thigh master. Suzanne Summers swore by it.
jeepinocala1111
Post by jeepinocala1111 » Mon Jun 20, 2016 11:31 am
Gary S wrote:Get your buddy a thigh master. Suzanne Summers swore by it.
You guys should already know we can't go around hurting people's feelings. No he's going to have to sit this one out.
Gary S
Post by Gary S » Tue Jun 21, 2016 9:24 am
now who's hurting feelings.
Post by SWAMPHUNTER45 » Tue Jun 21, 2016 9:37 am
Having thought about this for a bit the fastest way to increase your vessels buoyancy is thru the use of transom mounted flotation pods. Very common on flats boats but not often seen on airboats. It would be interesting to see how they would also work when running dry, recently I heard an old timer who built glass hulls talk about how a non-square shape breaks the hulls vacuum and helps a boat to run dry. I don't understand it but this old fellow has been airboating for 58 years so gotta respect that.
getchasumairboats
Post by getchasumairboats » Tue Jun 21, 2016 3:13 pm
I hunted for years out of a 12 ft boat and loaded many of 10-12 ft gators with no problem . Roll the gators in they load 10 times easier. 1 man can load a full grown gator that way.
http://WWW.USFTH.COM where the weak are killed and eaten !!!!!
jeepinocala1111
Post by jeepinocala1111 » Tue Jun 21, 2016 8:44 pm
getchasumairboats wrote:I hunted for years out of a 12 ft boat and loaded many of 10-12 ft gators with no problem . Roll the gators in they load 10 times easier. 1 man can load a full grown gator that way.
Yes we will make it happen no matter what we have to do.
