Ideas on how to set up rigging on fiverglass
I just bought my first airboat hull and looking for ideas on how to set up my rigging and how to go about setting it up on the stringers. Not sure what I need to build to bolt it to the stringers and the safest way. All ideas are appreciated and pictures are preferred so I can get a good idea
Re: Ideas on how to set up rigging on fiverglass
2nd from the left end of the above Menu Bar is a link titled >Pictures & Wallpapers
If you follow that link you will probably find a few dozen such examples as you scroll through what is there.
- kwanjangnihm
- Site Supporter - IV
here is a link and some pics to atvracer16 build last year - shows clean rigging to stringer setup!!
https://www.southernairboat.com/phpBB3/ ... &view=next
I think I'm wanting to run conduit, where would be the best place to buy from
- Southern Airboat Member
Can't really go wrong with using angle iron either.. I used about 6' of 1.5"x1.5" OR 2" x 2" angle for each stringer and then welded conduit to that.
- SouthRiver
- Site Supporter - II
- Contact:
Where are you located? That will help with your question as to where you can get the conduit.
"It is what it is......and...... "Everything happens for a reason, whether you like it or not......."
New boat is in the works..............
BCAA Member
N.R.A. Lifetime Member
BCAA Member
I am located in Tavares area
