Thanks in advance for any guidance! Purchased an older Texas built boat with a 220/0-470 GPU on her, and have had issues with misreadings on oil temp gauge from the get go. Replaced both the sensor (type that screws into the drain plug hole in bottom of oil pan), and the gauge, but still getting a reading that is about 100 degrees or so above actual temp. I have checked oil temp with infared gun, and even sanity checked that with cup of hot water and getting same results. I have replaced both the sensor, and the damn guage (faria/Teleflex brand purchased from local marine supply place). I've triple checked that all is hooked up correctly, and made sure I'm getting good ground, etc. Any ideas on what the hell is going on? If gauge were actually a water temp vs. oil temp gauge, could that affect anything?
on a side note.. I am installing CHT sensors and gauge as well to monitor engine health, but would still like to be able to accurately see oil temp as well. Thanks a ton!
Kyle in Texas.
Having issues with oil temp sensor and incorrect reading???
- Southern Airboat Member
- Site Supporter - III
Re: Having issues with oil temp sensor and incorrect reading
Can you verify the oil sender and gauge match ranges? Ohm range
- Site Supporter - V
put a mechanical gauge on her.....simple and accurate
I wasn't aware of the OHM ranges varied on different gauges.. but that could definately explain it. Any idea how I would be able to tell that? I like the idea of a mechanical gauge as well.. where could I get one of those that would jive with my 220 GMAC 76?
Many thanks!
Many thanks!
If you are using a Faria guage you have to use their sender. And understand Teleflex and Faria are 2 different companies. And both will tell you us their senders only.
Treasurer FAA
Svcliche@yahoo.com
Treasurer FAA
Svcliche@yahoo.com
Many thanks gentlemen. My local auto parts store had a mechanical gauge, so I picked up for $80 and installed last night. Hopefully I'll be good to go. Thanks again for the help!
Just for info only, I have found that the Autometer mechanical temperature gauges are super accurate and tend to be a bit better made with the coated thermal tube and anodized fittings.
Let us know the results
