Flex pipe exhaust insert
swamp runner
Postby swamp runner » Sat Dec 31, 2016 11:44 am
Looking to find what people are using for flex pipe insert exhaust system . Any info would be helpful . Thank you
12' HAMANT ULTRALIGHT - 180 LYCOMING - 68" CYPRESS SERIES
Re: Flex pipe exhaust insert
Postby SWAMPHUNTER45 » Sat Dec 31, 2016 12:32 pm
I have always put the flex pipe over the muffler or header collector and then used a flex pipe band clamp to keep it attached. Some guys will then run a small stainless screw thru to double lock it.
swamp runner
Postby swamp runner » Sat Dec 31, 2016 3:17 pm
Thx , they only make 3 " , and i have 2 1/2 "
Postby SWAMPHUNTER45 » Sat Dec 31, 2016 5:44 pm
Alumitec has 2 1/2 stainless flex for $9 a foot fyi check their web site and they ship.
Postby Deano » Sat Dec 31, 2016 7:44 pm
I've never had any problem getting 2 1/2" at NAPA.
Band clamps for both lap and butt joints can be had at Summit.
As Swamphunter eluded to, drilling a hole and using a set screw is cheap easy insurance
that can be easily removed if you need to make a swamp side repair (unlike a tack weld).
Krahammer
Postby Krahammer » Sat Dec 31, 2016 9:19 pm
I have a 10foot piece if 2 1/2 stainless. PM me if interested. A 2 and a half inch flex pipe clamp will not work. I discovered this the hard way. Napa has the right size Flex coupling. It's a band clamp and works perfectly if you have two and a half inch exhaust header or crossover pipe, you will need to insert a smaller diameter tubing and spot welded in place to hold two and a half inch flex pipe and the two and a half inch exhaust together works very smoothly.
