Help setting up trailer
Duff0113
Post by Duff0113 »
Trying to change my trailer up a bit and would like to know what some others have as far as trailer setups. I'm replacing the bunks on it right now. However I want to set it up to be able to load it from dry ground with the winch at least. I think with a dovetail and/or a couple rollers I should be good but I'm concerned at the height of the rear of the trailer frame. I'm thinking a drop axle would put it too low. I've got 3 leafs on each side, could I remove one leaf on each to soften them up so the trailer will squat a little? Pics or measurements of your trailer rear would be great to help me here. Thanks.
Currently how it sits
jeepinocala1111
Re: Help setting up trailer
Post by jeepinocala1111 »
Duff0113 wrote:Trying to change my trailer up a bit and would like to know what some others have as far as trailer setups. I'm replacing the bunks on it right now. However I want to set it up to be able to load it from dry ground with the winch at least. I think with a dovetail and/or a couple rollers I should be good but I'm concerned at the height of the rear of the trailer frame. I'm thinking a drop axle would put it too low. I've got 3 leafs on each side, could I remove one leaf on each to soften them up so the trailer will squat a little? Pics or measurements of your trailer rear would be great to help me here. Thanks.
You could help a bit by raising the trailer hitch on your truck so that it is on a slight wheelie that will bring the back down a bit them put smaller wheels to lower it a bit.
AceNtheHole
Post by AceNtheHole »
On my old boat I had not only rollers on the dove tail, but also rollers about 3 feet up from the back of the trailer. They were welded to a bar which traversed the trailer from side to side, with a lever on the port side of the trailer. Whether launching or recovering the boat, just engage the lever and the two long rollers would lift up a few inches from between the bunks, and lift the boat. It would roll freely either way. Then disengage the lever when ready to trailer. I had a Palm Beach hull and the guy I bought it from used to almost always dry launch the boat. Worked well.
Dirtman
Post by Dirtman »
Just looking at the pic that you posted it looks as if just a dovetail at the rear would be enough to dry load. If you wanted to put a roller at the point where the dovetail attached to the trailer it would help as the hull went up onto the trailer but not sure if that is really necessary. JMO
Duff0113
Post by Duff0113 »
Dirtman wrote:Just looking at the pic that you posted it looks as if just a dovetail at the rear would be enough to dry load. If you wanted to put a roller at the point where the dovetail attached to the trailer it would help as the hull went up onto the trailer but not sure if that is really necessary. JMO
That is kind of what I was thinking. Two 12" rollers right at the crown of the trailer back and dovetail.
Duff0113
Post by Duff0113 »
[quote="jeepinocala1111"
You could help a bit by raising the trailer hitch on your truck so that it is on a slight wheelie that will bring the back down a bit them put smaller wheels to lower it a bit.[/quote]
It's got 13" wheels on it now. I tried out some 12" and it didn't lower it hardly any difference since there's only about 3" total difference in their diameters. I was disappointed haha
gator7272
Post by gator7272 »
What is your tongue weight like? The axle looks set back pretty far. I would look into a drop axle as well, you can choose from different drop distances..........
11.5 X 7.5 Alumitech
2.0 Ecotec LTG
2.38:1 Ballistic
3 Blade Whirlwind 2.0
Duff0113
Post by Duff0113 »
gator7272 wrote:What is your tongue weight like? The axle looks set back pretty far. I would look into a drop axle as well, you can choose from different drop distances..........
The weight on the tongue isn't actually too bad. It doesn't pull bad either. For what I got in the trailer I can't beat it.
Lwells
Post by Lwells »
I couldn't tell by the picture whether your hitch is on square tubing or not but if it is, have you thought about taking your hitch off and putting it on a piece of square channel and then mounting the square channel so its under the tube you took your hitch from so you can pull a release and when your boat hits the back of the trailer your trailer will tilt and then just run it up on it and it will tilt back down as you go on and lock in place. This would be very easy to do.
Duff0113
Post by Duff0113 »
Not a bad idea
