how low can the end of prop be in the boat and still be ok
dick2256
Postby dick2256 » Sun Jan 29, 2017 9:37 am
I am going to lower my motor
Re: how low can the end of prop be in the boat and still be ok
Postby Deano » Sun Jan 29, 2017 9:57 am
The realistic answer really depends on what power/prop you are asking about.
Typically, for a DD with a 72" prop, the rule of thumb has historically been
a beer can down and forward from the top of the transom.
At the other end of the spectrum, I've seen a big block with BIG prop down near
the stringers literally making it self bailing, and with no deleterious effect on thrust.
More info please . . .
What do have, where is it at now, and where are you wanting to move it to?
dick2256
Postby dick2256 » Sun Jan 29, 2017 10:06 am
DD 60" prop on that corvair Right now prop is about 1-1/2"s above the top of the boat
Postby Deano » Sun Jan 29, 2017 10:26 am
I wouldn't worry at all about dropping it 6 inches. That would put you 4.5" below the transom.
If you figure 6" on a 72" prop (which is known to be fine), that represents 1/12th or about 8.3 %.
The same difference in your case would be 60" x 8.3 % = 4.8" below.
The bulk of the air coming off the prop moves down the blade and then goes back.
There is very little thrust from the tip of the blade. If 4 1/2 - 5" below will accomplish what
you're after, I wouldn't worry about it at all.
Probably, a little more may be ok, but to much more may become the subject of justifiable debate.
dick2256
Postby dick2256 » Sun Jan 29, 2017 11:43 am
Ok Deano
I'll go 4-1/2 in the boat
it has always been an easy roller and that should help
I am pulling the engine to put in a few helicoils in some pan gasket bolts holes and 0-rings in the oil return tubes
and it just seems like a good chance to drop it
may be my last year but hope not
Postby Deano » Mon Jan 30, 2017 10:00 am
Not sure why you would say that, but I will agree,
and also say that I hope and pray that it is not either. :)
Bonefish
Postby Bonefish » Mon Jan 30, 2017 7:52 pm
"Typically, for a DD with a 72" prop, the rule of thumb has historically been
a beer can down and forward from the top of the transom. "
Now that's some genuine engineering right there :cheers: :toothy7:
dick2256
Postby dick2256 » Tue Jan 31, 2017 8:53 am
Deano wrote:Not sure why you would say that, but I will agree,
may be my last year of air boating not much traffic on the river I run on and at my age
it is some times a log walk if I would have engine problems
I even bought a new carburetor for that thing so looking forward to a few more years.
This johnboat has ribs and I tried 1/4" poly on it but could never keep it from leaking
Thinking about finding some used 1/2" poly and ripping it 2 " wide and putting a piece 2"s wide in between the ribs and 12 feet long
any idea how much weight I would be adding would be 14 pieces 2"s x 12"
it would be great protection against the larger rocks we have in this river
would like to find some older poly someone has removed
Users browsing this forum: dirtracer4 and 1 guest
