Reputable tilt trailer manufacturers
Missfire
Postby Missfire » Mon Feb 06, 2017 12:14 pm
Anyone know of a reputable trailer manufacturer that builds a tilt aluminum airboat trailer (magic tilt does not). Near central Florida. Thanks
Being built:
All Hamant 14 x 8
550hp Waterthunder
Oxbox 2.68
Sensenich 3 blade Jx 81"
jeepinocala1111
Re: Reputable tilt trailer manufacturers
Postby jeepinocala1111 » Mon Feb 06, 2017 12:16 pm
The best trailer builder is https://bstrailer.com/
Postby Deano » Mon Feb 06, 2017 3:29 pm
The other obvious answer would be to PM Smuggler on here, which would be my choice. He can and will build anything you need and/or want. A quick search will provide quite a few pics, here is just one of many that he's made. Not a tilt, just the first one I found:
Just curious, why is it that you need a tilt trailer?
Under normal circumstances, the boat in your signature wouldn't need one.
In any case, Chris (Smuggler on the board here) can help you out, whatever you need. 352-428-9626
Junker
Postby Junker » Mon Feb 06, 2017 5:43 pm
As Deano stated ................... Call Chris, he builds a fine trailer ................. purchased one from him last year, great guy to work with.
If "Reputable" is what your looking for, need not look any further.
14 x 8 Hamant
383 - 2.38 Stinger
80" 3 Blade
Stainless rigged
pirate
Postby pirate » Mon Feb 06, 2017 5:49 pm
I bought a trailer from Chris a couple of years ago. He's a no BS guy and will build what you wish at the price quoted.
Missfire
Postby Missfire » Mon Feb 06, 2017 6:50 pm
Thanks for the info,
Had a tilt before, hate bumping brakes, just my preference but thanx again
Being built:
All Hamant 14 x 8
550hp Waterthunder
Oxbox 2.68
Postby Deano » Mon Feb 06, 2017 7:20 pm
Nothing wrong with having a preference, I'm pretty sure we all got 'em. :thumbleft:
Postby SWAMPHUNTER45 » Mon Feb 06, 2017 7:23 pm
I can vouch for both B&S and Chris, both build a very good custom trailer.
My bet is Chris will be more willing to build exactly what you want.
getchasumairboats
Postby getchasumairboats » Mon Feb 06, 2017 8:12 pm
The trailer pictured above is mine. I have pulled it all over the state and not 1 issue. He builds a damn nice trailer.
http://WWW.********* where the weak are killed and eaten !!!!!
Prototype
Postby Prototype » Mon Feb 06, 2017 8:43 pm
Misfire,
I know exactly what your talking about and a good thought, BUTT?? there's always a butt!
Both builders above make a fine hauler "but" may not understand the longevity factor of the need or use? I would highly recommend some bronze insert bushings in the tilt mechanism. Most tilt's as your aware just ride on a 1/2" grade 8 bolt and wear what's ever the easiest! The aluminum will be no doubt the easiest to wallow out! A brass insert will provide a consumable for this need if there willing to design the tongue to clearance for it?
Sounds like your boat would have no problem climbing tree's or doing it for rec use on occasion but it also sounds like your looking for a M-F thing on a regular basis? Aluminum sucks as a dry pivot point!
Smuggler
Site Supporter - VII
Postby Smuggler » Tue Feb 07, 2017 7:49 am
Thanks for the plugs guys!! However for some of the reasons that Prototype listed and some more of my own, I won't build a tilt trailer. There is no doubt that I could, I just won't. I can make unloading my standard trailer easier by using the plastic covered boards and rollers on the tail, between the two it makes it super slick and very easy to get the boat off the trailer. If you would like to see some of my work, here is a link to my trailer photo album https://goo.gl/photos/8HkFV6zC8rgVqXrQ6 . Give me a call if you have any questions 352-428-9626.
Thanks Chris
Postby One Eyed Gator » Tue Feb 07, 2017 8:00 am
I got a trailer from Chris over year ago. Wanted a few thing different, he built me exactly what I asked for and there has no issue at all.
BTW Chris also only builds airboat trailer.
Missfire
Postby Missfire » Thu Feb 09, 2017 10:28 am
Going to contact him, plus he is only 2 miles from my house....buy local...
again thanks for all the info
Being built:
All Hamant 14 x 8
550hp Waterthunder
Oxbox 2.68
Missfire
Postby Missfire » Sun Feb 12, 2017 6:53 pm
Found out that there are 2 different Chris's building airboat trailers, one is in Brooksville with Custom
Airboat
Trailers and the other is in Melbourne with Dakota airboats. Not to snub one or the other but seems like the one in Brooksville is the one most are talking/referring to. The one in Melbourne does make tilt trailers and the one in Brooksville does not.
Being built:
All Hamant 14 x 8
550hp Waterthunder
Oxbox 2.68
Prototype
Postby Prototype » Sun Feb 12, 2017 8:13 pm
Missfire,
It never hurts to check around! I can vouch for Chis's work and Cliff's work as top notch! Custom Airboat trailers and B&S trailers respectively! I have also heard that Dakota builds a nice trailer but I've honestly never seen one in action! I thought I knew your goal but if you live 2 miles from Chris and can't work a deal for him to build you something that is clearenced for a easy tilt conversion,,, then go for a full steel package with a 1/2 inch grade eight bolt holding up your rig? I've never known/heard Dakota to build aluminum trailers?
Just an Idea but I know KARAVAN builds a sweet ass trailer too. Maybe you can convert a tilt pontoon trailer to fit your needs?
JAMES
Postby JAMES » Sun Feb 12, 2017 8:58 pm
Dakota AIRBOATS builds one of the stronger trailers on the market !! Best price and have mso
pontoon outlaw
Postby pontoon outlaw » Sun Feb 12, 2017 9:44 pm
Chris of Dakota Airboat Trailers does build both steel and aluminum Tilts.... I've seen them Tilts in action,,, just pull up and pull the pin and boat slides off simple''' and he is on Facebook also,,, :thumbleft:
