Plan design foar airboat France
Arnaudd
Postby Arnaudd » Tue Mar 14, 2017 11:56 am
Hello. I am Arnaud j live in France here in no hydroplane or then paq many. Not power I look for design plan to build to few loan 16 feet. With engine 150hp. I do not find. Thank you for your help(assistant) and hello for France!!
glades cat
Re: Plan design foar airboat France
Postby glades cat » Tue Mar 14, 2017 5:22 pm
Sorry Arnaudd. No plans, only pictures. 16' boat good. Need beaucoup chevaux.
Postby Deano » Tue Mar 14, 2017 5:56 pm
Glades Cat is correct on both counts.
There are no such plans available in the public domain, and 16' is a good sized airboat.
Probablement, au moins doubler votre estimation d’origine.
Postby kwanjangnihm » Tue Mar 14, 2017 6:22 pm
Les femmes comme les gars avec de grands moteurs lycoming!! :thumbleft:
Arnaudd
Postby Arnaudd » Wed Mar 15, 2017 11:40 am
Thank you for your answers! I do not know towards what to make then
Barry830
Postby Barry830 » Wed Mar 15, 2017 1:26 pm
Barry830
Postby Barry830 » Wed Mar 15, 2017 1:27 pm
glades cat
Postby glades cat » Wed Mar 15, 2017 2:28 pm
Le airboat C'est une dependance tres cher.
Postby kwanjangnihm » Wed Mar 15, 2017 6:31 pm
Je vois toujours de grandes femmes poitrine sur les bateaux de moteur d'avion. :toothy7:
Arnaudd
Postby Arnaudd » Thu Mar 16, 2017 10:11 am
Hello. J saw the glenL plan of airboat. somebody knows? It is with engine Volkswagen of 50ch seems to me very low(weak)..
Arnaudd
Postby Arnaudd » Thu Mar 16, 2017 10:12 am
Arnaudd
Postby Arnaudd » Mon Mar 20, 2017 10:34 am
Deano wrote:Glades Cat is correct on both counts.
Hello! You think 300hp?
I have in the reduction the size of the boat in 14.5"
Weight of the only hull(shell) without engine without just driving chair the hull(shell) how many horses it is necessary and how many people on the boat? Thank you the friends
Postby Deano » Mon Mar 20, 2017 4:30 pm
My 300 hp minimum guess was in reference to your initial 16' projection and its load.
If you cut back to 12' and minimize your load, then your 150 hp could work if you keep it light.
Be aware that the Glen-L you linked above, is not built or braced enough for such an engine.
I've not seen those plans, but you are talking around three times as much power.
You will need to add a frame or two and/or beef up the stringers you mount the engine to.
How does your engine compare with that VW engine as far as weight goes ?
Ultimately, the success you have will be contingent on the never escapable, power/weight ratio.
